Hondata Tuned Hatch/B18c1 Dyno
Old May 10, 2003 | 03:54 PM
GruvyTune's Avatar
New User
Default Hondata Tuned Hatch/B18c1 Dyno
Car belongs to "95C1V1CSI"
95 Civic Hatch with stock sleeves/block guard and forged pistons/rods with MaxRev Manifold and Skunk2 manifold. P28 Ecu 550 injectors
Only limiting factor was the injectors which were maxing out at 14psi. The 18psi run below was a mistake but it made over 400HP.
Datalog: Note the aberrant ignition timing curve! This seems like a glitch in the hondata software and was NOT 30degrees advanced in boost.
Modified by GruvyTune at 1:17 PM 5/11/2003
Old May 10, 2003 | 03:57 PM
Mr. Softee's Avatar
Default Re: Hondata Tuned Hatch/B18c1 Dyno (GruvyTune)
man you were running pretty lean...
also shoulda kept revvin
Old May 10, 2003 | 04:08 PM
Evil DOHC's Avatar
Default Re: Hondata Tuned Hatch/B18c1 Dyno (94goldjungsr)
Why was the ignition advanced so much on the top?
EVIL
Old May 10, 2003 | 04:55 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Hondata Tuned Hatch/B18c1 Dyno (Evil DOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil DOHC &raquo;</TD></TR><TR><TD CLASS="quote">Why was the ignition advanced so much on the top?
EVIL</TD></TR></TABLE>
Looks like they let off.
Old May 10, 2003 | 05:02 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">man you were running pretty lean...
also shoulda kept revvin </TD></TR></TABLE>
actually he is rich. lower numbers on lambda scale and AFR scale mean richer, higher is obviously then lean
Old May 10, 2003 | 05:11 PM
Mr. Softee's Avatar
Default Re: Hondata Tuned Hatch/B18c1 Dyno (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">
actually he is rich. lower numbers on lambda scale and AFR scale mean richer, higher is obviously then lean </TD></TR></TABLE>
I disagree. hes at 1 lambda in the final few hundred RPM.. thats a 14.7:1 a/f ratio.
Not something Id want...
Old May 10, 2003 | 05:26 PM
LEON's Avatar
The only place I see the 1 lambda is at the end with the spike... which i'm sure is where they let off of the throttle, and then when he's back on it but that's in vac.
Old May 10, 2003 | 06:16 PM
Full-Race Javier's Avatar
which T3 turbo?
Old May 10, 2003 | 07:03 PM
GruvyTune's Avatar
New User
Default Re: Hondata Tuned Hatch/B18c1 Dyno (LEON)
the fueling is dead on perfect. the tuning was even more refined on the street. I always spend more time tuning on the street to get all the hesitation tuned out. You would never know this car from a stock car until the boost kicks in and pins your head to the seat.
As for the timing, as I said, there is a flaw in the Hondalogger software that shows the wrong advance on the high cam in boost!!!!!! I confirmed it with a dial back timing light (I put my head under the hood while he ran boost and watched the timing actually pull back in boost) so all is good!!
I'll let the owner of the car comment further if he wants.
Old May 10, 2003 | 07:04 PM
BrokenVtec's Avatar
another great job torin....
Old May 10, 2003 | 07:08 PM
servion's Avatar
Default Re: Hondata Tuned Hatch/B18c1 Dyno (BrokenVtec)
What fuel presssure is he at? I thought you could go a little farther with 550's... I might have to do an upgrade soon
Old May 10, 2003 | 08:04 PM
Full-Race Geoff's Avatar
Default Re: Hondata Tuned Hatch/B18c1 Dyno (javierb14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by javierb14 &raquo;</TD></TR><TR><TD CLASS="quote">which T3 turbo?</TD></TR></TABLE>
can you do it on rpm instead of mph too
Old May 10, 2003 | 09:34 PM
dfoxengr's Avatar
hes mostly at .9<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">
Not something Id want...</TD></TR></TABLE>
Old May 10, 2003 | 09:49 PM
T3's Avatar
T3
What size of turbo?
Looks good..
Old May 10, 2003 | 11:15 PM
Evil DOHC's Avatar
Default Re: (T3)
What do you think you are running as far as timing at full boost?
EVIL
Old May 11, 2003 | 04:47 AM
GruvyTune's Avatar
New User
Default Re: Hondata Tuned Hatch/B18c1 Dyno (servion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">What fuel presssure is he at? I thought you could go a little farther with 550's... I might have to do an upgrade soon </TD></TR></TABLE>
pressure 48psi static
Old May 11, 2003 | 04:49 AM
GruvyTune's Avatar
New User
Default Re: (Evil DOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil DOHC &raquo;</TD></TR><TR><TD CLASS="quote">What do you think you are running as far as timing at full boost?
at full boost timing is at 24degrees max
(road runner server down this morning so pics are not up right this sec)
Old May 11, 2003 | 04:57 AM
GruvyTune's Avatar
New User
Default Re: Hondata Tuned Hatch/B18c1 Dyno (FFgeoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FFgeoff &raquo;</TD></TR><TR><TD CLASS="quote">
can you do it on rpm instead of mph too</TD></TR></TABLE>
yes....
lets see if this shows:
Modified by GruvyTune at 1:15 PM 5/11/2003
Old May 11, 2003 | 05:01 AM
GruvyTune's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">hes mostly at .9</TD></TR></TABLE>
actually as boost comes on strong, it shows about 0.86-0.88 but you can see that settles out to 0.82 or so. I also know that there is a slight offset the Honda ECU sees vs what I know the A:F to really be at since there is a slight voltage drop at the ECU vs what my wideband display reads. I have not taken the time to adjust for the impedence of the Honda ECU with my wideband (common problem for a lot of people!)
Old May 11, 2003 | 06:05 AM
AVATAR's Avatar
Come on corey, let us know how it drives. Glad everything is together.
Old May 11, 2003 | 07:56 AM
FredoSP's Avatar
nice torin, thats why youll be doing mine very soon, I promise
Old May 11, 2003 | 07:57 AM
95c1v1cs1's Avatar
Default Re: Hondata Tuned Hatch/B18c1 Dyno (AVATAR)
Guys, Torin is a great tuner. He takes much consideration in making sure that the tuning is right on target. As for the hondata, i think there are a few flaws that we talked about with the boost level, and timing. He had the ***** to sit in front of the car while dynoing and read the timing under boost.
Street tuning is great. It really makes your car a very smooth drive and i highly recommend it to all people. It really does drive like a stock car(with boost of course)
I did just want to thank Torin for everything. I will be back to see him even tho it takes 9 hrs to get here.
BTW Avator, The car pulls really really hard. It sets me back in my seat for sure.
for "Gruvytunes"!
Old May 11, 2003 | 07:59 AM
95c1v1cs1's Avatar
Default Re: (T3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3 &raquo;</TD></TR><TR><TD CLASS="quote">What size of turbo?
Looks good..</TD></TR></TABLE>
Its a T3/T04E 60 trim
Old May 11, 2003 | 08:03 AM
BrokenVtec's Avatar
Default Re: Hondata Tuned Hatch/B18c1 Dyno (95c1v1cs1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95c1v1cs1 &raquo;</TD></TR><TR><TD CLASS="quote">Guys, Torin is a great tuner. He takes much consideration in making sure that the tuning is right on target. As for the hondata, i think there are a few flaws that we talked about with the boost level, and timing.
for "Gruvytunes"!
i have to agree.... torin's a great guy.....he really cares how your car comes out when he tunes it.....not like some other shops who are just in it for the $$..... he deffinatly gets two big
Old May 11, 2003 | 08:47 AM
GruvyTune's Avatar
New User
Thanks guys for the positive feedback. Tuning is definitely part science, part art. Mostly patience, though to get it right. I guess my situation is different. People drive very far at times to get to me so I do my best to get it right the first time. That means spending the majority of the time on the street getting the part throttle tuning dead on to tune out hesitation. Some times with many add ons its not 100% but usually gets very close.
I'll reitterate. Its crucial to take the time to make sure everything works perfectly before taking your car to the shop to get it tuned. Don't rush. Its easy to be impulsive because of the addictive nature of boost!!! I'm sure BrokeVtec can attest to this. Poor guy's car puts out 500HP but we're pulling out hair out over a stupid intermittent bug in his timing.
For those who have been PM'ing me with bug issues about the Hondata software, I have reported them to Hondata and they seem to be quite real ---specifically the timing logs and the MAP sensor readings that read too low on the Version 3 software.
torin
