How To? Make OEM foglights work w/o harness
Old May 10, 2003 | 02:23 PM
The Poopsmith's Avatar
Default How To? Make OEM foglights work w/o harness
How would I make OEM 94-97 foglights work w/ the OEM wiring harness? specifically, what relay to use? what connections to make? etc.
Old May 10, 2003 | 08:08 PM
Padawan's Avatar
Darth ModerVader
Default Re: How To? Make OEM foglights work w/o harness (DeeSeeToo)
There are low-cost relay wiring kits for auxiliary lights available at Pep Boys and other similar stores. I believe Rally makes one such kit, though there are other brands as well. The basic instructions will be included with the kit.
To sum it up, you will ground the relay, then run a power lead from the battery to the relay. A second lead runs from your desired activation source (e.g. parking lights, head lights, etc.) to the relay. The third (power) lead runs from the the relay to the lights themselves. The switch is placed in-line in the activation (parking, headlamp, etc.) lead, and that basically covers it.
Old May 11, 2003 | 10:46 AM
BolivianFuego's Avatar
Default Re: How To? Make OEM foglights work w/o harness (Padawan)
So I would need to run another line to my battery? Sorry I don't know how relays work...
Old May 13, 2003 | 07:05 AM
Default Re: How To? Make OEM foglights work w/o harness (BolivianFuego)
what gauge size should I use to wire up the fogs?
Old May 13, 2003 | 08:20 AM
o_Rage_o's Avatar
14 should be fine if your going directly to the battery (I used 12 to do my HID's only cause I had it laying around), join them before the battery and get them wired up to an inline fuse before conncting the other end of the fuse to the battery.
10 Amp fuse should also be fine, it may pop right away though, in which case you'd have to use 15. if that pops, its hooked up wrong
-Rage
Old May 14, 2003 | 06:35 AM
Default Re: How To? Make OEM foglights work w/o harness (o_Rage_o)
ok, I have an OEM fog light switch, but no switch harness! Could somebody tell me which pins do what? please, in dire need of help....
For purposes there are 5 pins, one on the top level, and 4 on the bottom level
HELP
Old May 14, 2003 | 10:39 AM
tC_Dragon's Avatar
the oem instructions indicate to use a 15amp fuse.
Old May 14, 2003 | 06:28 PM
Default Re: How To? Make OEM foglights work w/o harness (pdcdragon)
up
Old May 14, 2003 | 06:51 PM
Mikey's Avatar
Bump to the guy who bought this off of me!
Old May 15, 2003 | 10:30 AM
Default Re: How To? Make OEM foglights work w/o harness (Mikey)
bump...is that you the LS supercharged coup?
Old May 15, 2003 | 01:50 PM
Mikey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeeSeeToo &raquo;</TD></TR><TR><TD CLASS="quote">bump...is that you the LS supercharged coup?</TD></TR></TABLE>
I sold that car in January.
Old May 15, 2003 | 02:46 PM
streetlights's Avatar
i just have these OEM foglights as well and also wondered how to do this...i read the above posts but was wondering if i could use a generic switch to turn the lights on and off??is it worth doing all this for these foglights...and does anyone know how much a relay kit and a switch might cost for a setup like this? and finally has anyone ever wired these up without the wiring harness??If yes can they please tell us how long it took and if it was worth it? thanks a lot
Old May 15, 2003 | 02:58 PM
slowacura's Avatar
Default Re: How To? Make OEM foglights work w/o harness (streetlights)
you can pick up a generic fog light harness w/ relay and switch at pepboys for about 15 bucks
Old May 15, 2003 | 04:52 PM
Default Re: How To? Make OEM foglights work w/o harness (inteGSR)
I would pick that up, its just I want to use the OEM switch.
ok, now i have to vent:
GOD DAMNIT, WHY CAN"T I FIND THIS ******* HARNESS IVE BEEN LOOKING FOR 5 MONTHS FOR THIS POS WHY WHY WHY WHY WHY!!!!!!!!!!
Old May 15, 2003 | 06:18 PM
Mikey's Avatar
Look at http://www.acuraautomotiveparts.org under accessories.
Old May 15, 2003 | 06:28 PM
acura stopped sellin individual components of the OEM fog light kit. The only way to get just the harness is to pay $275 (lowest i found from barranco) for the entire fog light kit.
Old May 15, 2003 | 07:02 PM
98R-1144's Avatar
i actually found a post in an archived thread that showed what pins were needed. however i tried that and one of my fuses kept blowing. i gave up on that USDM switch... it'd be better off to buy the harness...otherwise, find a jdm switch or goto pepboys for a ghetto rocker switch
Old May 15, 2003 | 07:58 PM
samcVW's Avatar
if you want to wire fogs by themselves.. + - and a relay connected to your headlgiht switch or whatever to turn them all.
thats all you need.
Old May 20, 2003 | 11:07 AM
Default Re: How To? Make OEM foglights work w/o harness (samcVW)
any more help w/ using the OEM switch
NovaRex
Apr 20, 2015 02:14 PM
doubleoazn03
Lighting
Mar 8, 2012 11:44 AM
ohsnapzafingcu
Mar 13, 2009 10:38 PM
marc-111
26
Jan 15, 2005 08:55 PM
kerryk
Apr 26, 2003 03:54 AM
