Any JDM aftermarket headers???
Old May 10, 2003 | 12:16 PM
87sivtec's Avatar
Default Any JDM aftermarket headers???
My problem is the PR3 ecu for the B16 is looking for 2 02 sensors and i need an exhaust header that has two bungs. Is there any available here in the North American market?
I am sure that there was plenty made for the JDM area. Anyone have one for sale?
I am located in the BC area.
Old May 10, 2003 | 12:34 PM
RCautoworks's Avatar
Default Re: Any JDM aftermarket headers??? (87sivtec)
Yes you can find them around, try http://www.hmotorsonline.com, why not just buy the american header and have then weld another bung in ?
Old May 10, 2003 | 01:06 PM
87sivtec's Avatar
Default Re: Any JDM aftermarket headers??? (90blackcrx)
I think that i will. I was just curious about the pairing of the cylinders for the 02 sensors and the location of the sensors themselves.
If I could get better performance with a well designed header over makeshifting a US header then it might be worth it.
Thanks for the info.
Lyle
Old May 10, 2003 | 05:00 PM
Ruby Civic's Avatar
JUST get a muffler shop to weld them....they are 18mm fine thread or cut some bungs off of other old like junkyard hondas and use their bungs. i have doone that 3 times for b16a & crvtecs...
Old May 10, 2003 | 05:01 PM
Ruby Civic's Avatar
o2 sensors should be located about 12 in. "downstream" of the head, on header and some say the 2 allow for twin bank tuning of two cylinders each
Old May 10, 2003 | 06:29 PM
1_bad_EF's Avatar
Default Re: Any JDM aftermarket headers??? (Ruby Civic)
So, which o2 sensor goes where? Can I run just one sensor in the collector of a JDM ITR replica? Will it work w/no CEL's or drivability prob's????
After I figure this out, I will just have to find a way to make it fit.(read: hack the sh#t out of my front crossmember)haha doesnt make me too happy but.........
Old May 10, 2003 | 09:38 PM
Default Re: Any JDM aftermarket headers??? (1_bad_EF)
You will need to run both, or else you will have a code. And I have cut my cross member and have not noticed anything bad from cutting it.
Old May 11, 2003 | 11:24 AM
Ruby Civic's Avatar
so use the number one and number three header pipe...also k member gets weak if you cut it down...what about z ten or place racing replacement k member
Old May 11, 2003 | 01:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruby Civic &raquo;</TD></TR><TR><TD CLASS="quote">so use the number one and number three header pipe...also k member gets weak if you cut it down...what about z ten or place racing replacement k member</TD></TR></TABLE>
On a stock header the 02 sensor is on header pipe number 1 and , not 3. And even if you cut your cross member, I highly doubt you will even notice it is cut.
Old May 11, 2003 | 04:51 PM
Ruby Civic's Avatar
we were talking about doing it with two o2 sensors so that would be the correct position that i stated - please read the words, so it would be on the #1 and the #3 primary header tube as stated
4DRmafia
11
Jan 30, 2007 06:15 PM
JOE_EG2
19
May 21, 2005 05:55 AM
Dran
May 3, 2005 09:00 AM
beastrx
Aug 19, 2004 06:53 PM
racerxadam
Dec 26, 2001 04:57 PM
