Gotta make this ITR lower tie bar work!
Old May 10, 2003 | 11:30 AM
P1mpSlap's Avatar
Default Gotta make this ITR lower tie bar work!
I got stuck with this ITR lower tie bar (OEM) b/c I was randomly buying **** and thought it was just the trunk bar.
Well no matter, I gotta make this thing work. The Type R and GSR Lower Control arm diagrams on Acuraautomotiveparts.org do not come up (RED X) and I cannot pick out the parts that I need to make this thing work.
Anyone know exactly what I need? Or should I just toss it on ebay?
Old May 10, 2003 | 02:56 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Gotta make this ITR lower tie bar work! (P1mpSlap)
I think you 'll have to drill some holes in the lower subframe to make it fit. Try looking for a pic of the bar on an ITR ans see how it mounts. But remember the subframe on the ITR is a lot thicker than on the GSR and have the holes predrilled to fit the bar. But not so on the GSR.
Or you may want to throw it up on ebay and buy a neuspeed lower tie bar or something.
Good luck.
Old May 10, 2003 | 03:28 PM
Kelvin96GSR's Avatar
25 Year Member
Default Re: Gotta make this ITR lower tie bar work! (Gee3)
http://ownerages.com/ITRinstall.htm
Old May 10, 2003 | 04:09 PM
tC_Dragon's Avatar
Default Re: Gotta make this ITR lower tie bar work! (Kelvin96GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kelvin96GSR &raquo;</TD></TR><TR><TD CLASS="quote">http://ownerages.com/ITRinstall.htm
i think he is referring to the lower tie bar not the rear sway bar. In which case i don't know if its even possible becuase i believe the subframe is way different on the itr's. i don't think we will have a flat mounting surface like teh itr does at that point.
Old May 10, 2003 | 04:39 PM
Tweakmeister's Avatar
Default Re: Gotta make this ITR lower tie bar work! (pdcdragon)
you gotta drill the subframe.
even still I don't think it will work all that well.
Buy a Neuspeed and be done with it.
Old May 10, 2003 | 04:55 PM
IntEGNYC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdcdragon &raquo;</TD></TR><TR><TD CLASS="quote">
i think he is referring to the lower tie bar not the rear sway bar. In which case i don't know if its even possible becuase i believe the subframe is way different on the itr's. i don't think we will have a flat mounting surface like teh itr does at that point.</TD></TR></TABLE>
This guy's on the money.
Old May 10, 2003 | 05:29 PM
P1mpSlap's Avatar
thanks a bunch.
It'll go on ebay whenever I stop being lazy.
JDM_FRONTIN
Suspension & Brakes
Oct 22, 2007 10:27 AM
Transport
May 3, 2004 09:06 AM
Carpediem291
Feb 1, 2004 04:13 PM
jdmcivicferio
Mar 30, 2003 06:35 PM
RedGSR
Oct 2, 2002 10:12 AM
