Grinding when clutch is disengaged...(not "gear grinding")..tranny experts
Old May 10, 2003 | 10:37 AM
MikeMAN's Avatar
Default Grinding when clutch is disengaged...(not "gear grinding")..tranny experts
When i press the clutch the sound goes away, but when i release, the sound makes a slight grinding/rubbing noise. The RPMS will go lower and lower if I do this over and over until they stay at around 1000 rpms or so.
I was thinking this was the tranny idler gear? anyone else with input?
Old May 10, 2003 | 11:15 AM
salbaje's Avatar
Default Re: Grinding when clutch is disengaged...(not "gear grinding")..tranny experts (MikeMAN)
yes throw out bearing is not installed correctly.
Old May 10, 2003 | 11:33 AM
Aron Parsons's Avatar
Default Re: Grinding when clutch is disengaged...(not "gear grinding")..tranny experts (salbaje)
If it was the throw-out bearing, it would make the noise with the clutch pedal pushed in (with the clutch dis-engaged). It could be any of the bearings down there; check your pilot bearing first, and if necessary, crack the tranny open to check things out in there.
Old May 10, 2003 | 12:44 PM
Chiovnidca's Avatar
Mainshaft bearings maybe?
Old May 10, 2003 | 06:46 PM
MikeMAN's Avatar
Default Re: Grinding when clutch is disengaged...(not "gear grinding")..tranny experts (Aron Parsons)
doubt its the throwout bearing...has like 500 miles on it, so does the clutch
mike
Old May 10, 2003 | 07:11 PM
ScottEK's Avatar
mainshaft gets my vote.
DeeJaaY209
14
Sep 15, 2013 10:40 PM
04civicex84
Honda Civic (2001 - 2005)
Nov 13, 2008 02:44 PM
oinkus
Apr 19, 2005 05:06 PM
CR-VTEC EG
Nov 2, 2004 04:57 AM
Ditdogs
Apr 17, 2004 10:57 PM
