Help with GREDDY injectors, any special bushings needed?!?!
Old May 10, 2003 | 10:30 AM
KStuned's Avatar
Default Help with GREDDY injectors, any special bushings needed?!?!
Ok, so I know RC injectors don't go into the rubber bushing like stock injectors but rather they sit on top of them and clamp down, but I have GREDDY 720cc injectors, and they seem quite a bit different than stock. I am trying to put them in my H22, I just need to know if I should try to install them just the way they are, but if I do then it seems that the tip of the injector will be much farther away from where the tip would be with a stock injector, and I am worried about fuel not spraying where it is supposed to spray, possibly causing poor atomization.
Who has Greddy injectors and how did you install them? I just want to make sure that I do it right the first time. Thanks guys.
Old May 10, 2003 | 12:11 PM
KStuned's Avatar
Default Re: Help with GREDDY injectors, any special bushings needed?!?! (Hondaddict)
ttt
Old May 10, 2003 | 01:11 PM
94mugenintegra's Avatar
check PM
Old May 17, 2003 | 11:09 AM
KStuned's Avatar
Default Re: Help with GREDDY injectors, any special bushings needed?!?! (94mugenintegra)
seriously, who has Greddy injectors?
Old May 17, 2003 | 01:43 PM
Smashback's Avatar
foozball26 runs some 720cc Greddys I believe.
mike93eh
May 13, 2005 08:05 AM
ski_rebel_3
Apr 2, 2003 12:00 PM
AGen2integra
May 23, 2002 04:20 PM
The Punisher
Aug 25, 2001 07:50 AM
