Help with GREDDY injectors, any special bushings needed?!?!
Ok, so I know RC injectors don't go into the rubber bushing like stock injectors but rather they sit on top of them and clamp down, but I have GREDDY 720cc injectors, and they seem quite a bit different than stock. I am trying to put them in my H22, I just need to know if I should try to install them just the way they are, but if I do then it seems that the tip of the injector will be much farther away from where the tip would be with a stock injector, and I am worried about fuel not spraying where it is supposed to spray, possibly causing poor atomization.
Who has Greddy injectors and how did you install them? I just want to make sure that I do it right the first time. Thanks guys.
