B18b or Suspension...
Old May 10, 2003 | 07:31 AM
phillycx's Avatar
Default B18b or Suspension...
If you had $1800 and a 2000 CX would you do suspension (ground controls and koni yellows) or engine (b18b) first? The car will be daily driven and autox-ed on the weekends. (In case your curious, I chose the b18b because it's cheap and will give me the torque I need to get around the track.) Thanks in advance.
Old May 10, 2003 | 07:33 AM
clintwsi's Avatar
Default Re: B18b or Suspension... (phillycx)
if it is a good b18 then I would definitly get it first! then do the suspension.
Old May 10, 2003 | 07:38 AM
IntegraXSi's Avatar
B18
Old May 10, 2003 | 07:47 AM
phillycx's Avatar
Default Re: (IntegraXSi)
anyone else...? How about some responses from autoxer's? Also, say why...if you've got a reason...thanks.
Old May 10, 2003 | 08:14 AM
Cheivic's Avatar
Default Re: (phillycx)
1800$ for just ground controls and koni yellows? If you're serious about auto-x'ing or track use, get some Tein's or some other full coilover set. That motors nothing if you can't take turns or put the power to the ground. That's why high horsepower mustangs and cobras, get beat by Miata's.
Old May 10, 2003 | 08:22 AM
dohcdelsol's Avatar
unless the b18 is a once in a life time opurtunity, i would go with suspension. like the guy that said up top, no point to a good motor if ya cant handle the turns. but since it's a 2000, ur suspesion should be able to handle the b18 for a while untill u have the $$$ for the suspension. go with the motor cause they can haul some serious ***!!!!!!!!
Old May 10, 2003 | 08:23 AM
phillycx's Avatar
Default Re: (Cheivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cheivic &raquo;</TD></TR><TR><TD CLASS="quote">1800$ for just ground controls and koni yellows? If you're serious about auto-x'ing or track use, get some Tein's or some other full coilover set. That motors nothing if you can't take turns or put the power to the ground. That's why high horsepower mustangs and cobras, get beat by Miata's.</TD></TR></TABLE>
I wasn't planning on using the whole $1800 on suspension...it would be the ground control/koni's, and tires. How much would that Tein set-up cost?
Old May 10, 2003 | 08:24 AM
phillycx's Avatar
Default Re: (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">unless the b18 is a once in a life time opurtunity, i would go with suspension. like the guy that said up top, no point to a good motor if ya cant handle the turns. but since it's a 2000, ur suspesion should be able to handle the b18 for a while untill u have the $$$ for the suspension. go with the motor cause they can haul some serious ***!!!!!!!!</TD></TR></TABLE>
You said to get both...which on is it?
Old May 10, 2003 | 08:29 AM
Cheivic's Avatar
I've seen Tein's go for 900 used. And 1200 brand new. With that you can still get some Falken's.
Old May 10, 2003 | 09:12 AM
skribblah's Avatar
"power is nothing with control"
Old May 10, 2003 | 09:53 AM
Cru Jones's Avatar
Suspension
GC/Koni is a great combo
Tein is not legal for some classes
Old May 10, 2003 | 09:56 AM
ntrinsik's Avatar
Go with the suspension.. the motor swap will put you in a much harder class.
Old May 10, 2003 | 10:02 AM
Ovaltine's Avatar
Default Re: (skribblah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">"power is nothing with control"</TD></TR></TABLE>
Wha? So power is everything without it?
Old May 10, 2003 | 10:07 AM
GetawayInMoscow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">"power is nothing without control"</TD></TR></TABLE>
Old May 10, 2003 | 10:10 AM
Ovaltine's Avatar
Default Re: (GetawayinMoscow)
I know, it was just a joke. " "
Old May 10, 2003 | 12:46 PM
StreetMod's Avatar
Get the suspension first. Learn how the drive the car and tune suspension. Then go for more power, as you will be be better equipped to handle it.
Old May 10, 2003 | 01:48 PM
bikeboy80's Avatar
Default Re: B18b or Suspension... (The Sheriff)
nice choice with the b18b
but yea i would wait on the motor for now,
koni's with ground contols will be plenty for what you need, then spend the rest on some nice tires and a rear sway bar
of course i could tell you to wait and learn how to drive the car first
Old May 10, 2003 | 02:38 PM
phillycx's Avatar
Default Re: B18b or Suspension... (bikeboy80)
thanks for all the responses guys...still deciding The ground cotrol/koni's would be cheaper too, which would leave money for the frount strut bar and tires...hmmmm.
Old May 10, 2003 | 05:12 PM
drunknbass's Avatar
if you do decide you want a motor hit me up at aaron@drunknbass.com i have a 98 b18b1 with 40k super clean complete longblock with exhaust man and harness for 1000$
Old May 10, 2003 | 07:22 PM
Mike_C's Avatar
Either way the car won't be competitive in it's class for AutoX. I'd say you'll have more fun with the engine upgrade.
Old May 10, 2003 | 07:29 PM
The Destroyer's Avatar
Default Re: (JMU1337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMU1337 &raquo;</TD></TR><TR><TD CLASS="quote">Either way the car won't be competitive in it's class for AutoX. I'd say you'll have more fun with the engine upgrade.</TD></TR></TABLE>
I agree, and if u get that guys B18 for 1g, u still have 800 to spend on suspension
Old May 10, 2003 | 07:40 PM
drunknbass's Avatar
Default Re: (MagillaGorilla)
or gsr tranny
udontknowjack
Jun 23, 2010 10:12 AM
jtbsurfer
Aug 29, 2007 12:35 PM
91dxcrx
Dec 21, 2005 05:40 PM
yellowturbo
Dec 27, 2004 10:25 AM
aw1234dude
Jun 7, 2003 09:12 AM
