B18b or Suspension...
If you had $1800 and a 2000 CX would you do suspension (ground controls and koni yellows) or engine (b18b) first? The car will be daily driven and autox-ed on the weekends. (In case your curious, I chose the b18b because it's cheap and will give me the torque I need to get around the track.) Thanks in advance.
Re: (phillycx)
1800$ for just ground controls and koni yellows? If you're serious about auto-x'ing or track use, get some Tein's or some other full coilover set. That motors nothing if you can't take turns or put the power to the ground. That's why high horsepower mustangs and cobras, get beat by Miata's.
unless the b18 is a once in a life time opurtunity, i would go with suspension. like the guy that said up top, no point to a good motor if ya cant handle the turns. but since it's a 2000, ur suspesion should be able to handle the b18 for a while untill u have the $$$ for the suspension. go with the motor cause they can haul some serious ***!!!!!!!!
Re: (Cheivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cheivic »</TD></TR><TR><TD CLASS="quote">1800$ for just ground controls and koni yellows? If you're serious about auto-x'ing or track use, get some Tein's or some other full coilover set. That motors nothing if you can't take turns or put the power to the ground. That's why high horsepower mustangs and cobras, get beat by Miata's.</TD></TR></TABLE>
I wasn't planning on using the whole $1800 on suspension...it would be the ground control/koni's, and tires. How much would that Tein set-up cost?
Re: (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">unless the b18 is a once in a life time opurtunity, i would go with suspension. like the guy that said up top, no point to a good motor if ya cant handle the turns. but since it's a 2000, ur suspesion should be able to handle the b18 for a while untill u have the $$$ for the suspension. go with the motor cause they can haul some serious ***!!!!!!!!</TD></TR></TABLE>
You said to get both...which on is it?
Re: (skribblah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah »</TD></TR><TR><TD CLASS="quote">"power is nothing with control"</TD></TR></TABLE>
Wha? So power is everything without it?
Re: (skribblah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah »</TD></TR><TR><TD CLASS="quote">"power is nothing without control"</TD></TR></TABLE>
Re: B18b or Suspension... (phillycx)
Get the suspension first. Learn how the drive the car and tune suspension. Then go for more power, as you will be be better equipped to handle it.
Re: B18b or Suspension... (The Sheriff)
nice choice with the b18b
but yea i would wait on the motor for now,
koni's with ground contols will be plenty for what you need, then spend the rest on some nice tires and a rear sway bar
of course i could tell you to wait and learn how to drive the car first
Re: B18b or Suspension... (bikeboy80)
thanks for all the responses guys...still deciding The ground cotrol/koni's would be cheaper too, which would leave money for the frount strut bar and tires...hmmmm.
if you do decide you want a motor hit me up at aaron@drunknbass.com i have a 98 b18b1 with 40k super clean complete longblock with exhaust man and harness for 1000$
Re: (JMU1337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMU1337 »</TD></TR><TR><TD CLASS="quote">Either way the car won't be competitive in it's class for AutoX. I'd say you'll have more fun with the engine upgrade.</TD></TR></TABLE>
I agree, and if u get that guys B18 for 1g, u still have 800 to spend on suspension
aw1234dude
06-07-2003 09:12 AM
