help asap?
Old May 10, 2003 | 05:18 AM
krookedeg6's Avatar
Default help asap?
hey
i kinda got a response but not really sure if the answer was right just wanted to double check. i have a mini me swap using the vx bottom end which i am using the 5 wire...and i am using the p28 ecu which (i hear is 4 wire) can i just go anywhere and get a 02 for a SI or EX (since i have been told they are the same exact o2 sensor) and just using that the way it sits or do i have to hard wiring it in and miss one wire. if anybody has a idea bout this problem let me know...or if you know why i am putting up code 48 which is heated 02 sensor thanks guys
Old May 10, 2003 | 09:20 AM
SpoonFedHatch's Avatar
Default Re: help asap? (krookedeg6)
here you go bro...this should be more than helpful, i had the SAME exact problem
https://honda-tech.com/zerothread?id=422679
lamafia781
Dec 6, 2009 08:22 AM
duckmanEG
Aug 19, 2004 04:16 PM
ransack
Apr 7, 2004 03:57 PM
sicx
Mar 18, 2004 08:16 AM
Kamin
Feb 14, 2002 08:16 PM
