Car makes a metalic scratching noise when turning left. Possible fixes?
Old May 10, 2003 | 03:03 AM
keys's Avatar
Default Car makes a metalic scratching noise when turning left. Possible fixes?
My car makes a sound similar to a metal plate scratching metal whenever I make an extreme left(steering wheel turned all the way to the left). After closer inspection I'm pretty sure the brake dust shield is rubbing on something whenever I make an extreme left. The question is what could it be and how can I fix it? Now here is what stumped me: It only makes the sound when I'm going a little faster than idling speed. So that means it only rubs at faster speeds and I can't check it after jacking up the car because whenever I turn the wheel while it is jacked up, it isn't rubbing. TIA
Old May 10, 2003 | 07:47 AM
bert039's Avatar
Default Re: Car makes a metalic scratching noise when turning left. Possible fixes? (keys)
you might want to check your brake pads to see if they are worn. i had the same problem a while back and it just turned out to be the brake pad clip scrapping on the rotor.
Old May 10, 2003 | 08:14 AM
keys's Avatar
Default Re: Car makes a metalic scratching noise when turning left. Possible fixes? (bert039)
ok, I'll check that out, but the only thing is I just replaced my rotors and brake pads a couple months ago
Old May 10, 2003 | 09:10 AM
arsenaldragster's Avatar
is your car lowered? it might be the wheel rubbing on the inner fender.. Hope this helps!
Old May 11, 2003 | 07:47 AM
MASSGS-R's Avatar
I had some incompetent mechanic put a tie rod end on the wrong way when replacing it so that the curve of it faced out-when turning the wheel hard to that side the wheel rubbed against the tie rod end. I fyou had your tie rod ends replaced recently then I would check this out.
Old May 11, 2003 | 08:22 PM
keys's Avatar
Default Re:
hmmm...... I'll check that out too.... if it has been rubbing on the wheel then I should see scratches on the wheel too right?
Old May 11, 2003 | 08:36 PM
teggy98's Avatar
Default Re: Re: (keys)
Mine was doing that just before i replaced my breaks. As a temperary fix, just push/bend the shield back, it worked for mine. Are we talking about the rear wheels??
Old May 11, 2003 | 08:43 PM
keys's Avatar
Default Re: Re: (teggy98)
no it's the front wheels
Old May 11, 2003 | 08:53 PM
teggy98's Avatar
Mine was the rear, but its worth a shot. Just bend the shield like a quarter inch back from the rotor. If you have small enoufgh spokes you can reach between them and dont even need to remove the wheels. While your at it, spray it down with some break cleaner to loosen/ clean any rusty parts.
b20acura
Jun 28, 2011 12:20 PM
pcguy760
Apr 8, 2007 03:52 PM
casmello
Oct 16, 2005 11:14 AM
cracker099
Sep 6, 2002 05:57 PM
RolioPolio
Jun 29, 2002 01:38 AM
