For All Motor running Eagle Rods....
would you considered upgrading the rod bolts on the eagle from the 2000 series to the 625 series ? 200 series are known to stretch under higher revving motor, not so much an issues with FI guys.
Do any of you have similar issues with Eagle 2000 rod bolts ?
stan
stan
I have been using std eagle rods with whatever they come with. no problems
with sustained high rpm yet. Not to say it wont ever happen, anything can happen,
but i think i abuse it more thoroughly than most.
I have run Eagle rods in the 30 or so motors I 've built . One the B20Vtecs N/A motors hits peak power around 9300RPMs and I know it's seen 10 K many times No problem !. And the B20 has the longest stroke which put the rods bolts through some abuse.
People are on the " Eagle rods break at 200WHP" Kick, I use then all the time. Plus they size more consistant than most I've used.
JunIntegra
14
Oct 29, 2003 01:12 AM
