Need confirmation. 90-91 TEG ECU same as 92-93???
Old May 9, 2003 | 08:22 PM
squirrel's Avatar
Default Need confirmation. 90-91 TEG ECU same as 92-93???
My girlfriends 92' DA just burnt its ecu. Is the ecu the same as the one from '90 teg? I think I might have one laying around somewhere.
Thanks kids
Old May 9, 2003 | 09:18 PM
bhive9024's Avatar
Default Re: Need confirmation. 90-91 TEG ECU same as 92-93??? (squirrel)
they are not the same. 90-91 integras are obd0 and 92-95 integras are obd1. that is not to say that you cant use an obd1 ecu on an obd0 car. It just takes more than unplugging and plugging to make it compatible.
Old May 11, 2003 | 09:29 AM
Bill W's Avatar
Default Re: Need confirmation. 90-91 TEG ECU same as 92-93??? (bhive9024)
Confirmation, they are different. You can use an ecu from 92-3, or the 94-5 one also works (as long as they aren't the VTEC versions). The PR4 and P75 computers will work for you, in OBD1 configuration. Be sure to match up and use either the manual or automatic versions based on what you have now.
If you need one, shoot me an email I have one for $75 if you are interested it's a manual transmission version, 94-5 style.
00CivicGirl
Nov 30, 2007 05:36 PM
Stewie
Sep 24, 2004 04:02 PM
shermanyang
Aug 18, 2002 04:50 PM
