Mugen Radiator Cap
Old Jul 6, 2001 | 11:11 PM
KJ's Avatar
KJ
Default Mugen Radiator Cap
Is anyone running the Mugen Radiator cap on the ITR? My engine gets VERY hot and I was wondering if this would help keep it's temperature a little lower...
Thanks
Old Jul 6, 2001 | 11:22 PM
t's Avatar
t
Default Re: Mugen Radiator Cap (KJ)
It will help a little bit, get the thermostat also. Or get a bigger radiator. Have you tried water wetter?
You could also slide the heater to full hot
Old Jul 6, 2001 | 11:29 PM
AJ PwR's Avatar
Low temp Thermostat, bigger rad and oil cooler will help your engine runs cooler.
Old Jul 6, 2001 | 11:39 PM
Mike M's Avatar
Founding Member
Default Re: Mugen Radiator Cap (AJ PwR)
You could try my setup
Fluidyne 40mm radiator, Greddy oil cooler, spoon thermostat, rad cap, and thermostat switch
Old Jul 6, 2001 | 11:47 PM
AJ PwR's Avatar
Default Re: Mugen Radiator Cap (TypeRmsm)
Mike,
Are you running a thermostat for the oil cooler????
Old Jul 7, 2001 | 07:03 AM
Dropspeed's Avatar
I'm running the mugen radiator cap, and thermostat the car runs much cooler than stock, have never had a problem with it getting past the 1/2 way point on the gauge even with 20 minute sessions at the track.
Mattj
Old Jul 7, 2001 | 07:14 AM
Mike M's Avatar
Founding Member
Default Re: Mugen Radiator Cap (Dropspeed)
Ben- Yes, it was included in the kit from Greddy
Old Jul 7, 2001 | 07:45 AM
Kengs's Avatar
Mike,
I IMed and e-mailed you as requested. No reply back.
What was it you wanted? E-mail me back.
Old Jul 7, 2001 | 08:14 AM
KJ's Avatar
KJ
Default Re: Mugen Radiator Cap (kengs)
I just flushed my radiator and put in:
33% Havoline Coolant
65% Water
2% Water Wetter
(not the exact proportions, but you get the picture).
My car still gets heatsoaked after one hard run so I think I need more.
I'll try the radiator cap first (since it's easy to install and I won't "waste" my new coolant flush).
Then I'll try the thermostat, and if all else fails, I'll get a radiator (avoiding this since it's MAD $$$).
Thanks for the reply's!
KJ
P.S. What's the downside of running a Higher Pressure Radiator Cap?
Old Jul 7, 2001 | 08:37 AM
spoonek4's Avatar
Just remember u TCed your car man...it must run cooler to avoid blow something up
Old Jul 7, 2001 | 08:50 AM
Hooch'n's Avatar
Default Re: Mugen Radiator Cap (spoonek4)
The Mugen Radiator Cap and Thermostat help a lot. It runs a little cooler on the street and helps cooling on the track. Good Stuff
Old Jul 7, 2001 | 09:32 AM
La Chilindrina's Avatar
Default Re: Mugen Radiator Cap (8400-RPM)
I ordered my thermostat and hopefully I get it TODAY!!!! Ohhh yeah and I have the rad cap too... I am a happy chic
Old Jul 7, 2001 | 11:36 AM
Jason's Avatar
You guys notice any difference between the spoon and the mugen rad cap? the mugen is 1.3, the spoon is 1.35...but the mugen is $30, and the spoon is $50...worth the extra 20 bucks???
Old Jul 7, 2001 | 11:57 AM
Hooch'n's Avatar
Default Re: Mugen Radiator Cap (typer98)
No there is not that much of a difference, I'd go Mugen.
Old Jul 7, 2001 | 12:47 PM
Big Phat R's Avatar
Get a low-temp thermostat before the cap.
Old Jul 7, 2001 | 01:00 PM
sackdz's Avatar
Default Re: Mugen Radiator Cap (Big Phat R)
My car NEVER goes over halfway even on the track.... what's the point? What temperature is halfway on the stock guage?
Old Jul 7, 2001 | 03:02 PM
KJ's Avatar
KJ
But a thermostat will only allow coolant to start flowing earlier, but eventually once the coolant heats up...the low-temp thermostat will be useless. (correct me if I am wrong).
Old Jul 7, 2001 | 05:55 PM
rudeS2k's Avatar
in my opinion,ill get the Spoon radiator cap..my 2cts
Old Jul 7, 2001 | 09:26 PM
SuspectProduct's Avatar
New User
Go here for the Spoon cap. It's like $33 and some change.
http://www.inlinefour.com/spoonhigradc.html
Old Jul 7, 2001 | 09:41 PM
rudeS2k's Avatar
Default Re: Mugen Radiator Cap (SuspectProduct)
speaking of Spoon..where in the bay area,can i get one?
Old Jul 8, 2001 | 12:48 AM
spoonek4's Avatar
Yes u're right the thermostat allow coolant to circulate earlier. But since your car is moving the coolant keeps cooling down at the radiator. Like it opens at 68c, so when it gets to that temperature the coolant starts to circulate and cool down the engine anyway to prevent the temp gets any higher. That's why the temp needle stays low after u got a thermostat. It only goes higher if u got into a traffic jam, when the car is not moving or moving fast enough to cool down the coolant. Then it will go a bit higher but STILL lower than the stock normal temperature.
I don't know if this make sense to u but just sharing some thoughts here
Old Jul 8, 2001 | 12:54 AM
spoonek4's Avatar
Old Jul 8, 2001 | 08:06 AM
KJ's Avatar
KJ
OK, that makes sense, but I'm worried it might be bad to run my car below the "optimal" temperature all the time.
I gotta think of some sort of heat shield for my filter.
I MIGHT even have to get a HOOD scoop!!!!
Old Jul 8, 2001 | 10:14 AM
Ibuprofen's Avatar
forgive my ignorance, but what is an thermostat?
Old Jul 8, 2001 | 10:41 AM
98Psi ITR's Avatar
Default Re: Mugen Radiator Cap (ITyp3R)
Did you switch your fan to manual?
