fuel concentration problems
Old May 9, 2003 | 07:03 PM
Spudddy's Avatar
Default fuel concentration problems
i have a 97 integra gsr with a drag gen 3 turbo. it has a crane ignition also. i am having a problem with the car when it goes over a large bump, or gets jolted hard. the fuel concentration seems to be getting out of whack. before the car his a bump it runs fine and the a/f guages goes from lean to rich, up and down, like it should. after it hits the bump it stays at rich when i have my foot on the gas, and as soon as i take it off a little it goes to stoich, there is no inbetween. the car also backfires alot when its like this. if i turn the car off then turn it back on everything goes back to normal. i was thinking maybe it was some sort of sensor or electrical piece but im not sure. any info is appreciated. thanks.
Old May 9, 2003 | 10:08 PM
hybridreams's Avatar
Default Re: fuel concentration problems (Spudddy)
Have you tried posting this in the Forced Induction forum?
Old May 10, 2003 | 12:24 AM
IN VTEC's Avatar
It sounds like you're being switched into open loop.
Maybe there's a short in the TPS, or if you have a VAFC, maybe there's a short in the wiring there.
Old May 10, 2003 | 06:14 AM
Spudddy's Avatar
Default Re: fuel concentration problems (hybridreams)
i put it in the forced induction forum, but i think they removed it, thank you.
so you think i should buy a tps sensor? or the wiring might be lose?
Old May 10, 2003 | 06:17 AM
Spudddy's Avatar
i have a fields vtec/fuel controller, but i turn it off most of the time because it eats my gas, but it still gets messed up whether its on or off.
KtHaNxBai
13
Mar 27, 2006 08:43 PM
mastarolla
Jan 10, 2004 10:06 PM
awps
May 13, 2003 07:13 AM
95gsr
Jun 28, 2001 12:50 PM
