Vtec works then quits??????
Old May 9, 2003 | 04:40 PM
Hondasaurs's Avatar
Default Vtec works then quits??????
My vtec will come on when I 1st drive the car. After this it will not function unless I turn the car off and start it again. When it does this I get a Code 22, Vtec pressure. Then after restarting the code will go away then come back. I've done the basic checks like checking the oil level.
Any suggestion of what this may be or what is causing this? What can I do to correct it?
Old May 9, 2003 | 05:06 PM
slowdx's Avatar
Default Re: Vtec works then quits?????? (B17A Hatch)
Probably low oil, i know you said you checked it, but did you check it properly? What level was it at. Unless its a bad sensor? But ive never heard of a (vtec) oil pressure sensor going back
Old May 9, 2003 | 05:09 PM
Hondasaurs's Avatar
Default Re: Vtec works then quits?????? (slowdx)
The oil is fine. The vtec is fine for about 5 min of drive time once the engine is warmed up. After I hit vtec one time if quits and I get a Code 22.
Old May 9, 2003 | 06:20 PM
slowdx's Avatar
https://honda-tech.com/zerothread?id=501036 hes got the same problem. I dont know what else it could be man, sorry. Heres a bumo for ya.
Old May 9, 2003 | 08:51 PM
Shark Tank's Avatar
check and make sure the screen in the vtec solenoid is not clogged. next check and make sure your oil pump is working correctly...what weight oil are you using?
djSALIX
Nov 5, 2010 07:43 AM
FSS13foxtrot
Dec 28, 2007 12:32 AM
dkboyny11
Jun 2, 2005 03:45 PM
danteisme
Sep 26, 2004 03:19 PM
BobGnarly
May 23, 2004 05:28 PM
