Difference(s) between JDM ITR head and USDM ITR head?
Old May 9, 2003 | 04:36 PM
hybridreams's Avatar
Default Difference(s) between JDM ITR head and USDM ITR head?
Are there any? If so, what are they?
Old May 9, 2003 | 09:53 PM
Default Re: Difference(s) between JDM ITR head and USDM ITR head? (hybridreams)
Bump for the insomniacs
Old May 9, 2003 | 11:34 PM
Fowler.'s Avatar
As far as I know, the actual heads are the same. The intake manifold is different though. And the cams may or may not be. I haven't come to a conclusion on that yet.
Old May 10, 2003 | 05:45 AM
Nameless RB26's Avatar
Default Re: Difference(s) between JDM ITR head and USDM ITR head? (Green R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green R &raquo;</TD></TR><TR><TD CLASS="quote">The intake manifold is different though.</TD></TR></TABLE>
And how is that?
Cams.. are only different depending on which year of ITR head/s you are asking about..
Old May 10, 2003 | 07:02 AM
Fowler.'s Avatar
Default Re: Difference(s) between JDM ITR head and USDM ITR head? (Nameless EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">
And how is that?</TD></TR></TABLE>
Certain smog equipment. I think it's the EGR or something. I'll look at my manifold and my friends manifold today and I'll tell you for sure later on.
Old May 10, 2003 | 04:17 PM
sgT's Avatar
sgT
Integra does not have EGR.
JDM manifold is missing EVAP port and has an extra vacuum port
Old May 10, 2003 | 07:11 PM
bearingburner's Avatar
Default Re: Difference(s) between JDM ITR head and USDM ITR head? (sgT)
head and cams are identical. compression on jdm is slightly higher but thats on the lower short block. anyways dc2 has no egr. sgt is right on the evap and vacuum. the runners on the jdm intake manifold is shorter and slightly wider than usdm. the skunk2 one is perfect example of jdm itr manifold
philliedawg
Oct 17, 2007 05:57 PM
slayerfromhell212
Jan 16, 2007 09:41 PM
Suck my DX
13
Jul 3, 2005 09:32 PM
ras
Apr 18, 2005 07:06 PM
T I F O S I
Apr 4, 2004 03:31 AM
