If a VTEC controller gets stolen, will car run?
Yes it will still run. But depending on what ECU you are using, if it is a vtec, it will trigger the vtec when it is suppose to. But if not and you are setting off the vtec through one of the external systems, your car will run with no vtec.
Guest
Posts: n/a
yes, your are at the right track and your car will run like stock and the vtec will work.
TeamPacman...................Marouj
stupid is what stupid does............
http://www.atomicperformance.com
NO, it wont run like stock. When you hook up V-afc (and feilds most likely), you have to cut the vtec wire. One side goes into the vtec controller, the other side goes back out. So, if someone steals it the vtec wire will be broken, and the engine will throw a code. It WILL run, but no vtec.
_______
You don't actually cut off the Vtec wire that goes into the ECU. You are merely tapping into the wire. So when they steal the external unit, they are pulling the wire that was tapped into the original Vtec wire. Unless they yank the actual Vtec wire that lodges into the ECU, the Vtec will be activated at its original setting.
[Modified by b20b, 6:19 AM 7/9/2001]
_______
b20b, have you ever actually hooked up a vtec controler? The vtec controler cant control anything if the factory signal still goes directly to the vtec solenoid. Look at these instalation pics below. Also, i just got done instaling one in my own car over the weekend so i think i would know.
I'm not trying to start an argument or anything, but it sucks when someone gives you false info, expecially if they don't know it.
...you will have many opens in the factory wiring. The VTEC controller is wired IN-LINE with the factory signal wires and many codes will result from it's not being there.
Now if the thief was nice enough to rewire your car for you after he yanked out the controller then you're set.
-Kevin
-Kevin
hi i'm installing my fields sfc boxer series in my 91 civic si. i'm swapping the head w/ a sohc d16a6 head from a sohc vtec 94 civic ex. and i was wondering if you knew the wireing instructions for that swap. if anyone know's how to wire it any info would be greatly appreciated. if not i'll figure it out
haha, i remember when i took off my vafc. still had the harness on just unpluged the control unit. damn my car was idling between 500-1500 and burning gas like crazy. check engine light was on. didnt drive it though.....haha
bandit67
May 17, 2011 06:09 AM
[626] SiRJKwIcK89Ef
Oct 10, 2001 06:37 AM
