d16a1 high compression setup in d16 a6, z6, y8
i recently built a motor for my 89 hatch. its a d16z6 longblock with shoot peened rods d16a1 pistons nippon rings and clevite 77 bearings i am going obd1 here in a couple day's when my friend gives me his dizzy. and for now i have no vtec and am running a pr4 ecu (90-91 integra) ecu also i am running 94 octain (i know i should be running a race blend) its not running that bad but expect it to be a bit faster when i go obd1 i have no top end now without vtec but bottom end feels pretty good but its running a bit rich (due to the ecu.. i think)
does anyone have a similar setup??
list your setup
what gas do you run?
how do you feel about your high compression sohc??
thanks
-larry
list your setup
thanks
-larry
I have a friend running around with a Y7 bottom end, VX head, Y8 manifold, and it's a 97 4dr EK with a P28. It's turbo and running 9lbs and pull's pretty nice just an idea you know
LSVTEC426
Jun 28, 2007 03:05 AM
djsire
Aug 7, 2005 08:10 PM
underage
13
May 19, 2004 05:00 PM
