What will happen if the old "tin foil on the O2 sensor" trick fails?
Old May 9, 2003 | 12:23 PM
fredtoast's Avatar
Default What will happen if the old "tin foil on the O2 sensor" trick fails?
I have a 98 ITR (OBDII). I've read that if I want to run a testpipe I can just pull the O2 sensor from the cat and wrap it in tin foil (actually aluminium foil). I want to try this before I get rid of my cat, but I need to know what will happen if it doesn't work. Will I just get a CEL or will it throw my car into limp mode?
Old May 9, 2003 | 12:29 PM
Chris N's Avatar
Default Re: What will happen if the old "tin foil on the O2 sensor" trick fails? (fredtoast)
Just unplug the o2 and tape the other end of the connector either to the bottom of the car or just inside the hole that it feeds through so it is safe from harm.
You will get a CEL code.
You won't run in limp mode.
Old May 9, 2003 | 03:53 PM
Black R's Avatar
25 Year Member
.....i've always wondered if tricking the 2ndary o2 sensor has any negative effects.
Does it affect fuel trim or anything? Mileage goes up or down? Or just emissions crap?
Old May 9, 2003 | 04:34 PM
Dr Pooface's Avatar
Default Re: What will happen if the old "tin foil on the O2 sensor" trick fails? (Black R)
I think the second O2 is just there to ensure the cat is working. I noticed no ill effects with mine gone and the cel on.
Old May 9, 2003 | 04:41 PM
SW20 MR2's Avatar
You will get a CEL.
Old May 9, 2003 | 05:41 PM
Tuney's Avatar
Default Re: What will happen if the old "tin foil on the O2 sensor" trick fails? (SW20 MR2)
the foil worked for me, no cel in 5 months
C_Civic
11
Apr 20, 2004 07:34 PM
gsrvtechatch93
Mar 29, 2004 08:48 PM
Qwikrex
Aug 1, 2002 05:50 PM
Etylorcen
May 6, 2002 04:28 PM
degradated
Nov 5, 2001 02:57 AM
