New motor is in and running!
I got my car running last fridat after 5 months of waiting. I put type r pistons and cams in it. I also put a new rsr header and act 6 puck/ extreme plate with 8.5 lbs flywheel. I have put about 600 miles on it with no problems so far. I put on some aem cam gears to match my intake and pulleys. My question is what do you guys think I will run in the quater mile? I also have a blitz 2.5 diameter exhaust and will have a test pipe installed when I do go and run it. My other question is with my stock gsr ecu keeping the rpms to 8300 am I missing the full potential of the cams? What chips are good for this setup? thanks oh yea I have a spoon head gasket to add a little more compression.
Just go run it, there are too many variables at the track, esp the driver. I would suggest going with something like a Hondata S100 for your needs.
I was thinking low 14's high 13's. I will run the car once I put some more miles on it and get my test pipe the exhaust has no flex right know because the header was a little shorter than my dc.
Thanks guys! I still haven't taken it over 7,000 rpms but I am looking forward to those last 1,000. NA gsr do they just level off after 8100? It will be a while before I do the computer work but I will definately like something like the hondata.
what the HELL do you have the strong of a clutch in there for , thats altittle much dont you think . . .
edit: isnt that like 110% over stock , that for cars with real power goin to the wheels , like 300 whp . . . . or somthing of that sort
( not tryin to be a dick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jiz101 »</TD></TR><TR><TD CLASS="quote">You're not going to see 13s anytime soon with only those mods. I think you will run high 14s depending on your driving skill.</TD></TR></TABLE>
Yeah.
Maybe not HIGH 14s.... but mid-14s. Gotta give the guy the upper hand you know.
I say around 14.6xx on the perfect run.
The ITR cams make power well into 9K RPM. If you get a hondata and raise the revlimit. If you shift at 8K RPM then try shifting at 9K RPM at the track. The difference is almost .5 of a second.
Yeah.
I say around 14.6xx on the perfect run. The ITR cams make power well into 9K RPM. If you get a hondata and raise the revlimit. If you shift at 8K RPM then try shifting at 9K RPM at the track. The difference is almost .5 of a second.
I had a 6 puck before and needed a new flywheel. Its not as bad as you guys make it out to be. So mid 14's seem to be what you guys think it will run? I ran 15.1 with my bolt on stuff and stock internals.
DANG YO
Jul 3, 2005 05:40 PM
Malice
May 23, 2002 12:55 PM
