FS: Hondata P28 ECU
Old May 9, 2003 | 06:15 AM
flyrod's Avatar
Default FS: Hondata P28 ECU
I have an OBD 1 P28 ecu (controls VTEC) from hondata for sale: First $200 takes it. It has the rom socket installed and the connector for the Hondata link box. Will work with stage 2, 3, 4, and the new S200 stuff. It will also work with aftermarket roms (like the ones on ebay) if you prefer to go that route. Just plug the new rom into the socket and you're good to go. Here are a few pics:
Old May 9, 2003 | 06:39 AM
TRuST's Avatar
Default Re: FS: Hondata P28 ECU (flyrod)
Which hondata was the ECU socketed for ? (the old stage 2,3,4 series or the S200 series)
Old May 9, 2003 | 07:05 AM
flyrod's Avatar
Default Re: FS: Hondata P28 ECU (TRuST)
It will work with either. The socket is the same, as is the connector. I've been using it with a stage 4, but I can test it with a friend's S200 if you are worried about it not working. I bet you could also send it back to Hondata if there is some kind of problem.
Old May 16, 2003 | 12:10 PM
flyrod's Avatar
This lists for $250 on the hondata web site...
Old May 24, 2003 | 11:03 AM
flyrod's Avatar
Old Jun 9, 2003 | 05:53 AM
flyrod's Avatar
Guy flaked on a COD so I'm out $20. Still for sale...
Old Jun 21, 2003 | 10:43 AM
flyrod's Avatar
bumpity.
Old Jul 1, 2003 | 06:19 AM
flyrod's Avatar
Funny, when it was out for COD I had several ppl interested. Now that it came back, none. Guess that's the way it goes...
Old Aug 2, 2003 | 06:47 PM
flyrod's Avatar
Old Aug 2, 2003 | 08:01 PM
SBR*EG4's Avatar
The reason I stopped doing COD's is because of what happened to you...weak, good luck on the sale.
Old Aug 2, 2003 | 11:04 PM
nwdave's Avatar
Okay, so, this is just a P28 socketed for a Hondata chip? Is that right?
Forgive me for not understanding
Old Nov 20, 2003 | 09:59 AM
flyrod's Avatar
Default Re: FS: Hondata P28 ECU (delsolguy)
Yes. It was socketed by Hondata, for hondata, but it should also run any compatible rom, like the ones on Ebay all the time...
Old Nov 21, 2003 | 06:44 AM
93ludeSi's Avatar
what type of rom is with it, single use, or is it flashable?
Old Nov 21, 2003 | 09:11 AM
flyrod's Avatar
Default Re: FS: Hondata P28 ECU (93ludeSi)
It doesn't come with a rom. You can use a hondata rom, or one from Ebay, etc...
Old Nov 22, 2003 | 01:22 PM
93ludeSi's Avatar
okay, so its just a socketed p28, no baseline program or anything
Old Oct 14, 2004 | 06:12 PM
VSBB6's Avatar
Default Re: (93ludeSi)
Still available?
Old Oct 14, 2004 | 07:34 PM
gofastjdmcivic's Avatar
give a 100 for it
AzN_Flava
Engine Management and Tuning
Sep 15, 2017 10:33 PM
Rzoops
Sep 1, 2010 07:10 AM
turbodcxbro
Jan 9, 2010 11:31 AM
ScottFern
Sep 27, 2003 10:08 PM
