I bought Prelude - old oil question
Old May 9, 2003 | 04:37 AM
petrv's Avatar
Default I bought Prelude - old oil question
I have bought a 4G Prelude VTEC. The lude has oil changed in November 2000 and has 4000km on it (cca 2600miles). So the oil there was 2.5 year old and even if practically not much driven, was very black. So I changed it with filter and after 100km the oil is black again. What should I do? Another oil change? removing and cleaning the oil pan?
Old May 9, 2003 | 04:48 AM
JTCdudeman's Avatar
Master H Technician
Default Re: I bought Prelude - old oil question (petrv)
oil does that... Its a good idea to run it through a couple of times just to make sure evryhign is ok and out...
Old May 9, 2003 | 04:50 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: I bought Prelude - old oil question (JTCdudeman)
call your Honda dealer and ask if they offer "sludge-out" treatmeant..... it basically steam cleans the inside or your engine, it's good stuff
Old May 9, 2003 | 04:56 AM
93ludeSi's Avatar
how many miles are on the car??
Also vtec engines are prone to blow by which will also make the oil black quicker
Old May 9, 2003 | 05:03 AM
petrv's Avatar
Default Re: (93ludeSi)
It has 84.000 km (55.000 miles), year 1995. The lude more stayed than ran. Can the black color be because of such old oil (2.5 years in engine, but only 3k miles on it)?
Old May 9, 2003 | 05:20 AM
new2ludin's Avatar
Default Re: (petrv)
I'd go with what they said. Just change it, and run it for about two days, and do it again. After two or three times it should start to look good. At most auto stores you can buy some stuff to clean it. Buy Restore 4 too, it will help since your car has been sitting around for eight years.
Old May 9, 2003 | 08:37 AM
h2392si's Avatar
Default Re: (new2ludin)
what he said, try the Z-max stuff, works great , and get and engine flushed. Then change the oil again, then do a really good tune up i.e-the plugs, plug wires, the distributor cap, the rotor catp, transmission service, and dont run it too hard right away, ease into pushing it for a while.Peace
Old May 9, 2003 | 09:13 AM
PreludeRacer023's Avatar
Default Re: (h2392si)
run a good synthetic oil....ive run AMSoil which was very good...right now i use castrol syntec, and its worked great for me...my oil is translucent even after putting a few thousand miles on it...good stuff
meanshyguy
Mar 10, 2009 05:07 AM
951dc5
Jan 27, 2006 08:07 AM
redlineSH
Jul 27, 2004 07:32 PM
petrv
May 9, 2003 11:21 AM
albert butterbikini
Dec 10, 2001 04:12 PM
