Cluster Swapping in between 3rd generation Integras?? Any Problems
Old May 9, 2003 | 12:37 AM
horizonteg06's Avatar
Default Cluster Swapping in between 3rd generation Integras?? Any Problems
Well I am in the process of swapping my DC cluster I bought in My DA, and I also ordered a wire harness and found out the cluster I ordered had one as well, but I look at the wires and they all dont match up correctly, so here is my concern, as well as for others
Are these DC cluster really plug and play with each other. Like if I were to have a 94 LS and I swaped my engine, could I swap my cluster as well??, because they dont match up all correctly and its quite strange....
Anyone swap their clusters in their integra for a different model or year and had any problems?????
thanks
Old May 9, 2003 | 04:43 AM
sgT's Avatar
sgT
Default Re: Cluster Swapping in between 3rd generation Integras?? Any Problems (horizonteg06)
youare going to run into problems, because the DC integra uses an electric
speedometer, and the DA uses a mechanical one. So unless you change the VSS
and do a lot of wiring, its probably not gonna work.
Old May 9, 2003 | 04:39 PM
Default Re: Cluster Swapping in between 3rd generation Integras?? Any Problems (sgT)
no see that isny my problem, I already converted the VSS to electronic and it works, I do however have problems with the battery light and maybe my low fuel and cruise, but not too concerned with that, every thing is okay cept the battery
thanks
Old May 10, 2003 | 09:38 AM
Hey guys i got it to WORK!, Everything came out pretty well, cept have tested the Cruise or the Low Fuel Light, but I couldnt get the battery light fixed, too frustrating, anyways its cool, just took out the bulb, no need.
I will try to get pics up, I might do more moddin thats why
Later
SikAuto
Dec 2, 2008 11:16 PM
viskii420
Apr 16, 2006 10:23 PM
ronintegra
Jan 3, 2006 12:10 PM
88rexboy
Mar 31, 2004 08:42 AM
