who makes full coilover and shock set ups??
Old Jul 6, 2001 | 03:12 PM
wuhungsixxx's Avatar
New User
Default who makes full coilover and shock set ups??
who makes a full coilover and shock set up that has all the goodies such as adj. everything and camber plates for the EF?...u know...ALL THE GOOD STUFFFF...oh and if i decide to go with groundcontrols or skunk2(teamed with illuminais) whats a good spring rate for a crx w/ B18C that can get me going close to 1g on the skid pad?...thanks for the help
Old Jul 6, 2001 | 06:48 PM
91ED7Si's Avatar
Default Re: who makes full coilover and shock set ups?? (wuhungsixxx)
H&R
Old Jul 7, 2001 | 07:20 PM
EVOCELICA's Avatar
New User
Default Re: who makes full coilover and shock set ups?? (91ED7Si)
Tein
Old Jul 7, 2001 | 08:31 PM
IAMJUSTHERE's Avatar
New User
Default Re: who makes full coilover and shock set ups?? (EVOCELICA)
if you are going to get a full coilover setup, get the type r rear lower arms. then you can get any coilover setup for an itr and run it on your car. and there are unlimited systems for the itr.
Old Jul 7, 2001 | 10:20 PM
Trinity's Avatar
Tein
yes i second this one!!
Old Jul 8, 2001 | 06:16 AM
New User
Default Re: who makes full coilover and shock set ups?? (Trinity)
just to let you know, the tein's are a jdm model. what does this mean? it means that the jdm model has eye rear lower arms on the sir and not fork. so, with those you will need to buy type r rear lower forks as i stated above. but if you are going to do that, then you might as well get itr tein's.
Old Jul 8, 2001 | 08:30 PM
HyperREV's Avatar
New User
Default Re: who makes full coilover and shock set ups?? (JDMCRXB18C5)
go to a wrecker and find a set of 88 CRX Si LCA's
exact same thing as the ITR's, for alot less.
Old Jul 8, 2001 | 11:41 PM
Trinity's Avatar
Default Re: who makes full coilover and shock set ups?? (HyperREV)
i already have one. I am getting tein when i get the money for them
Old Jul 9, 2001 | 03:48 AM
TypeR0207's Avatar
I had planned on the Tein models, but did not realize that the R arms would actually fit on (although I already new that I would need them to work).
Anf the H&R are not fully adjustable ....... they are a complet integrated shock/spring model, but they do not have any dampning adjustability ....
And the Tein R shocks have like a 600/800 lb spring combo ...... pretty harsh for a 2,000 lb car! I wonder if the EF model uses a softer spring ..... hmmmm, have to ask God about that one.
Old Jul 9, 2001 | 05:35 AM
91sifreak's Avatar
New User
Well I have a b16a in my 91 si and I have ground control spring purches for koni 5 way struts, both for the 91 civic, but, I got the 90-93 teg spring rate springs and it really is nice the. The car is so tight now, also got all the sway and strut bars you can get for this vehicle. But that is just what I like
HONDA_TYPE_R
Sep 7, 2004 10:00 AM
Crackerballer
Dec 13, 2003 11:29 PM
jisu009
10
Apr 6, 2003 11:04 PM
UncleBen'sRacing
Dec 6, 2002 01:44 PM
RyanR
Sep 7, 2001 02:33 PM
