main&rod bearing colors on h23?
Old May 8, 2003 | 09:18 PM
ludesleep's Avatar
Default main&rod bearing colors on h23?
im calling camp1320 tomorrow to order some acl bearings...anyone know off hand what color i need? i know my rod bearings are all green but my mains are so old i cant see the color its warn off. Any help?
Old May 9, 2003 | 06:00 AM
LudeyKrus's Avatar
Default Re: main&rod bearing colors on h23? (ludesleep)
Same here; i was lookin into buyin new main bearings and I had no clue which color to buy. A motor-building friend told me it depends and there's no way to really tell until you pull the bearings. Anyone have an easier way?
Old May 9, 2003 | 08:20 AM
Greyout's Avatar
Default Re: main&rod bearing colors on h23? (LudeyKrus)
I thought you used the stampings on the rods, crank, and block....
Old May 9, 2003 | 11:50 AM
ludesleep's Avatar
Default Re: main&rod bearing colors on h23? (JDM LUDE)
you can but why not just ask someone who has already changed them?
Old May 9, 2003 | 12:09 PM
JG Luder's Avatar
each crank is different. It wouldn't matter.
You need to pull the crank, and look at the stamps on it. Just wipe away the oil, don't use any chemicals.
You'll be able to see it, and then you can call up camp and order what you need.
Old May 9, 2003 | 11:21 PM
PreludeRacer023's Avatar
Default Re: main&rod bearing colors on h23? (Lone Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lone Luder &raquo;</TD></TR><TR><TD CLASS="quote">each crank is different. It wouldn't matter.
You'll be able to see it, and then you can call up camp and order what you need.</TD></TR></TABLE>
exactly, every one is different so you cant just go by what someone elses was..peace
Old May 9, 2003 | 11:59 PM
ludesleep's Avatar
Default Re: main&rod bearing colors on h23? (PreludeRacer023)
well my block reads..from the oil pump side to the flywheel. 2,3,2,3,4...so is this yellow,green,yellow, green, brown? am i reading my helms right?
Old May 10, 2003 | 12:21 AM
aeolus's Avatar
ok,now you need the numbers off the crank just like the helms says.the numbers on the block tell you only half the story.
Old May 10, 2003 | 07:02 AM
Prelude Vtec 23's Avatar
Default Re: main&rod bearing colors on h23? (aeolus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeolus &raquo;</TD></TR><TR><TD CLASS="quote">ok,now you need the numbers off the crank just like the helms says.the numbers on the block tell you only half the story.</TD></TR></TABLE>
Exactly...get both sets look at your helms and you'll see what you need
Old May 10, 2003 | 07:25 AM
ludesleep's Avatar
Default Re: main&rod bearing colors on h23? (Prelude Vtec 23)
o ok..well my crank is being balanced and micropolished right now. Do they resurface cranks during the process? If they do, does that mean im gonna have to get different sizes than marked on my block&crank? thanks guys
Old May 10, 2003 | 08:46 AM
JG Luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesleep &raquo;</TD></TR><TR><TD CLASS="quote">o ok..well my crank is being balanced and micropolished right now. Do they resurface cranks during the process? If they do, does that mean im gonna have to get different sizes than marked on my block&crank? thanks guys
the marks will still be there. The micropolishing only applies to the journals.
Spoon84
Dec 31, 2007 01:18 AM
hybridpatient95
Apr 26, 2005 01:12 PM
Hoosier Daddy
Nov 9, 2003 01:20 PM
jbbrann
Oct 2, 2001 07:00 AM
