Installing B&M fuel pressure gauge on AEM fuel rail... what do I seal with?
Old May 8, 2003 | 07:54 PM
1point7T's Avatar
Default Installing B&M fuel pressure gauge on AEM fuel rail... what do I seal with?
I'm installing a B&M fuel pressure gauge on the AEM fuel rail..
the directions say not to use liquid Teflon or Teflon tape as a sealant for any tapered fitting on the fuel system..
they say to use only a lubricant or anti-seize on the threads..
does this mean that hondabond is out of the question?
what should I use? just a light coating of oil?
how long til I can post more than 5 times in 24hour period?
Old May 8, 2003 | 07:57 PM
sgT's Avatar
sgT
Default Re: Installing B&M fuel pressure gauge on AEM fuel rail... what do I seal with? (1point7T)
Use teflon tape or liquid teflon sealant. in this case works better than hondabond.
Old May 8, 2003 | 08:11 PM
1point7T's Avatar
Default Re: Installing B&M fuel pressure gauge on AEM fuel rail... what do I seal with? (sgT)
even though the directions explicitly state not to do that?
what's up with this 5 post/24hour limit????????????
Old May 8, 2003 | 08:12 PM
cajnatc's Avatar
Use the teflon tape
Old Jun 14, 2003 | 07:20 PM
J2turbo21's Avatar
Default Re: Installing B&M fuel pressure gauge on AEM fuel rail... what do I seal with? (cajnatc)
Do you need anything else or does the B&M gauge come with everything to install it on the AEM fuel rail?
Old Aug 22, 2003 | 04:48 PM
Charlie Moua's Avatar
what? I though the B & M gauge could only be mounted from the fuel filter and not directly to the rail... more info please.
fishnfst
Jun 30, 2004 06:58 PM
alpha
Jun 14, 2003 07:19 PM
greddyturboGSR
Mar 10, 2003 05:48 PM
Reddog
Sep 30, 2002 12:42 AM
