Battery Relocation Kit?
The kit is mad cheap, you could make your own kit, but I recommend buying one, it'll be easier. Also I think most of the kits don't include a "distributor." It's like a metal wire connector bracket you use to attach the new wires to the old ones. They're like 5 bucks at Radio Shack.
Sure, I believe this is the link to it:
http://store.summitracing.com/...=ecat
There are some other places that carry more expensive kits, like in the 100 dollar range, but the only thing they have that is different is a metal box, etc.
This kit should be fine. You'll only need to purchase the distributor, it's a little metal bracket that connects all the wires, and it mounts on the side of the engine bay. Generally I believe its for stereos or something, but it works fine for batteries, you can get them at Radio Shack I believe. Good luck, this is a very easy mod, and worth it!
Also you might want to get an Optima battery for it, these don't release any fumes or anything.
https://www.batterymart.com/battery.mv?c=optima
I've heard they are nice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastaccord94lx »</TD></TR><TR><TD CLASS="quote">The kit is mad cheap, you could make your own kit, but I recommend buying one, it'll be easier. Also I think most of the kits don't include a "distributor." It's like a metal wire connector bracket you use to attach the new wires to the old ones. They're like 5 bucks at Radio Shack.</TD></TR></TABLE>
i thought they ran from 50 to 100...if not just get that battery case which routes the batteries heat to the outside of your car...
Hey 94, thanks a lot, that is really cheap! 42.95
! The Yellow Top may be a little much for me right now because I'm putting together a turbo kit and it will be a lot easier to re-route the battery to the rear. Thanks for your help!
most tracks require relocated batteries to be ina box, which comes with the kit.
I would also recommend a hawker battery, they are alot smaller and lighter, and can be mounted in any position.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastaccord94lx »</TD></TR><TR><TD CLASS="quote">Also you might want to get an Optima battery for it, these don't release any fumes or anything.
the yellow top is good for starting with a system?
</TD></TR></TABLE>the yellow top is good for starting with a system?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReLL »</TD></TR><TR><TD CLASS="quote">
the yellow top is good for starting with a system?</TD></TR></TABLE>
yea should be fine. plus it wont die as fast as your regular battery. it allows you to use your system with your car off.
