leaking hydrolic clutch fluid.....
Old May 8, 2003 | 05:16 PM
94dxt's Avatar
Default leaking hydrolic clutch fluid.....
inside my car where the clutch pedal meets the firewall, fluid is leaking from behind the boot, I am running a heavy pedal Action 6puck clutch so the added pressure is probably pushing fluid through. Anyone had this problem or know how to fix/stop it? Thanks
Old May 8, 2003 | 05:21 PM
Kataku2K3's Avatar
Default Re: leaking hydrolic clutch fluid..... (94dxt)
Never had this problem using that clutch or anything of the like but if it's leaking you're most likely going to just have to replace the entire clutch master cylinder... Good Luck
Old May 8, 2003 | 05:36 PM
JimBlake's Avatar
Default Re: leaking hydrolic clutch fluid..... (Kataku2K3)
Time for a new master cylinder. BTW, the heavy clutch probably didn't have anything to do with it. The higher pressure is only in front of the piston; your leak is behind the piston and that's not pressurized when you press the pedal.
Old May 8, 2003 | 06:25 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: leaking hydrolic clutch fluid..... (JimBlake)
this is a very common problem on all hydraulic clutches...
fcjohnny
Nov 19, 2009 07:33 PM
hannslebo
Mar 24, 2009 01:53 PM
Mad Third Gear Vtec
Dec 24, 2008 10:59 AM
Lb1atx
Sep 7, 2007 05:16 AM
Hard2Find
Mar 12, 2002 03:17 PM
