Koyo oem replacement radiator???
Old May 8, 2003 | 04:38 PM
Propulsion's Avatar
Default Koyo oem replacement radiator???
will this perform better than the original, or should I go for the bigger all alluminum radiator after a h22/civic swap?
Old May 8, 2003 | 05:10 PM
aeolus's Avatar
Default Re: Koyo oem replacement radiator??? (SilverCIVIC96)
Ifyour talking about the bigger core radiator with the bigger inlet and outlets,yes,it will work good.
Old May 8, 2003 | 05:15 PM
Propulsion's Avatar
Default Re: Koyo oem replacement radiator??? (aeolus)
no, this is the one listed as oem replacement on radiators.com, supposed to be exactly like the oem one.
but knowing its coming from koyo, I thought it might yield a better cooling effect than the denso oem one. Plus the guy at radiator.com told me on the phone "it will perform same or better than oem" im just wondering how much better and if its enough for a H22?
thanx for the input
Old May 8, 2003 | 11:39 PM
aeolus's Avatar
well,the one i got from 1800 radiator was a direct replacement for the dohc del sol.Dual core,bigger outlets,same width as the stock one.
http://home.earthlink.net/~jo5...4.jpg
http://home.earthlink.net/~jo5...5.jpg
Modified by aeolus at 9:30 AM 5/9/2003
Old May 9, 2003 | 12:50 AM
im_poor's Avatar
how much did that cost??
Old May 9, 2003 | 04:40 PM
aeolus's Avatar
Default Re: Koyo oem replacement radiator??? (impoor)
close to 125.00.This is Koyo part number c1570.Most radiator places have it.
Modified by aeolus at 1:58 AM 5/10/2003
Old May 9, 2003 | 07:29 PM
Propulsion's Avatar
are you using your original fan? does it fit right, any trimming needed?
Old May 10, 2003 | 12:14 AM
aeolus's Avatar
i just got a flatter fan from pep boys.
Dc2 Powered
Mar 27, 2005 06:27 PM
94PearlWhiteGsr
Nov 4, 2004 08:36 AM
EnjoyTheRideDC2
Sep 19, 2003 07:49 AM
diabolik_projekts
Aug 17, 2002 06:08 PM
