what is a vtec controller?
Old May 8, 2003 | 04:18 PM
ahunt01's Avatar
Default what is a vtec controller?
I know this is a dumb question, but what exactually does a vtec controller do? I'm guessing you can program your car to engage vtec at lower RPMs? What would be the benifit/downside to that?
Thanks
Old May 8, 2003 | 05:03 PM
sslude's Avatar
Default Re: what is a vtec controller? (ahunt01)
well there is a VAFC which is a vtec and air fuel controller, it basically lets you fine tune your fuel and vtec engagement point. its a nice mod if you have IHE and a couple other parts
Old May 8, 2003 | 07:53 PM
blah13's Avatar
Default Re: what is a vtec controller? (sslude)
The VTEC Controller does just that, allows you to change VTEC engagement. The V-AFC adds air/fuel control as well. What you do is have 2 runs(or more) on a dyno, 1 with the small lobe up to redline and the next with the large(VTEC) lobe up to redline. You then compare the 2 torque curves and set VTEC to engage where they cross over (the small lobe drops in power vs the large lobe continues to make power) Badda bing.
Old May 9, 2003 | 03:29 AM
ahunt01's Avatar
Sounds like a nice addon, thanks for the help everyone.
Old May 9, 2003 | 08:02 AM
Resurgent's Avatar
Also good for adding a vtec head to a non vtec engine
pokmijn
Nov 24, 2007 07:28 PM
SOHC_MShue
Sep 18, 2002 09:27 AM
06Xrunner
Sep 7, 2002 07:06 PM
RexB16
May 4, 2002 03:27 AM
CivicEsEye
Jan 5, 2002 02:21 PM
