High idle on my B16a1 Any Suggestions>
My B16 started acting weird. The idle sits at like 2000 RPM . I had to redo the vacuum hoses to pass smog. And now it idles high. When I disconnect the hose on the dashpot diaphram it idles ok. What is the purpose of this dashpot thing?
The dashpot should pull in with vacuum, lowering the idle. It's main purpose is to open the throttle plate slightly during start up.
You say you "had to redo the vacuum hoses to pass smog. And now it idles high. "
Recheck your hose routing. You may have one or more connected to the wrong point.
96hatchBoy
Mar 28, 2013 06:17 AM
