displacement over-bore on a d series
Old May 8, 2003 | 11:20 AM
tek_civic's Avatar
Default displacement over-bore on a d series
how much extra displacement can i get out of my d16z6 without changing the crank or rod length? what all do i need to change? pistons obviously, get new sleeves? what all do i need to get this done? im gonna buy a spare d16 and build it on the side while i just use my norm d16 for driveing to work. so what liter displacement can i get outta the d16z6? will most any machine shop do it? any more info would be great, ps i searched but found no info on d16s doing this.
thanks
Old May 8, 2003 | 11:40 AM
Takeoff's Avatar
Default Re: displacement over-bore on a d series (tek_civic)
I talked to GE and they can put in 79MM max. There sales person couldn't give me displacement though.
Old May 8, 2003 | 05:16 PM
tek_civic's Avatar
Default Re: displacement over-bore on a d series (Takeoff)
cool, so thats 4mm over stock right? what would i do for pistons if i did bore it out to say, 79 or more? just get custom pistons? are they much more expensive? anyone else let me know if you have maxe bore sizes and if possiable displacements. will you need to sleeve the engine?
Old May 8, 2003 | 05:23 PM
JaeOne3345's Avatar
go to rsmachines.com look into one of thei sleeved blocks.
and yes you would need custom pistons.
use a simple displacement calculator like c speed orrr like this:
http://www.knology.net/~jediklc/D.htm all ya gotta do is search.
d16 normally has 75mm bore with 90mm stroke. all youre doing is playing with bore size, so lets say u went over bore to 79mm. just enter it in.
your new displacement is 1764.7870422016803 cc's
Old May 8, 2003 | 05:44 PM
RyanEJ8's Avatar
Default Re: displacement over-bore on a d series (JaeOne3345)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaeOne3345 &raquo;</TD></TR><TR><TD CLASS="quote">go to rsmachines.com look into one of thei sleeved blocks.
Yes.............I believe they have D-Series bore sizes of 75-80mm.
Old May 8, 2003 | 05:46 PM
tek_civic's Avatar
Default Re: displacement over-bore on a d series (RyanCivic2000)
damn, thanks a lot, thats pretty much exactly what i wanted,
what are my options if i wanted to increase the stroke?
oh and is a bored out turbo car streetable? with a boost controler of coarse. what about na? probibly not worth it on a z6, right?
Modified by tek_civic at 8:11 PM 5/8/2003
Old May 8, 2003 | 05:50 PM
JaeOne3345's Avatar
once again, contact rsmachines.
Old May 8, 2003 | 07:45 PM
tek_civic's Avatar
what about if i take the block to my local machine shop? will he need to reseleeve the block or can he bore the stock from 75mm to 79mm without resleeving?
Old May 8, 2003 | 08:22 PM
JaeOne3345's Avatar
no way dude. have u looked at the sleeve lining of a stock sleeve? its no where near thick enough. to go to 79mm, you need new sleeves for this.
Old May 8, 2003 | 08:30 PM
tek_civic's Avatar
where can i buy these new sleeves. and i have seen the cylender walls but it was a while ago before i started thinking about this so i didn'y pay much attention. where do i get new sleeves? will the machinist(i slaughtered the spelling right?) be able to order them for me? thanks for your help
Old May 8, 2003 | 08:31 PM
JaeOne3345's Avatar
dude not to be a dick but have you read the last 742875 post in this thread? u ask where to get sleeves but ive mentioned rsmachines.com a few times already. u send RS your block and they do it for you.
Old May 8, 2003 | 08:34 PM
tek_civic's Avatar
sorry, i went to their site but they don't have much info on anything really. just a very brief description of what they offer, i am going to call them tomarrow. tnx
Old May 8, 2003 | 08:37 PM
JaeOne3345's Avatar
http://www.rsmachines.com/blocks.html
hmm..pretty decent info in my eyes.
Old May 8, 2003 | 08:45 PM
tek_civic's Avatar
for a d series engine it doesn't say much, no prices, no turnaround time, no details, or anything like that. i was just wondering what was needed if i had a local guy do the bore job. thats all. i will jsut call around tomarrow, thanks for the info.
Old May 8, 2003 | 08:48 PM
Spade's Avatar
Turn around on any sleeve shop is a month. Just figure that period.
JG claims to be able to go to 81mm with the D series block BTW.
And costs are around a grand.
Old May 8, 2003 | 09:08 PM
boosted hybrid's Avatar
Default Re: displacement over-bore on a d series (Spade)
Another option is getting a deckplate made to go in conjunction with the sleeves. The deckplate with a custom rod will better the rod/stroke of the d-series. You would be able to better the high rpm volumetric efficiency and slow the piston speed down greatly to make the d-series a high rpm screamer. Without adding a custom stroker crank, the deck plate will give you less displacement but add in creating a better breathing high rpm engine.
Old May 9, 2003 | 08:25 AM
tek_civic's Avatar
Default Re: displacement over-bore on a d series (boosted hybrid)
thanks for the info. is RS machines the only place that sells a stroker kit for a d16? im gonna call them in a few minutes and ask some questions, thanks for all the help but in the end it might end up being too expensive for me. we will see.
one more question, how many pounds of boost can the stock sleeves take? is it cheap to just get the sleeves replaced to the stock bore? or will more work have to be done than im thinking? tnx
turbo_d
Dec 18, 2008 08:53 AM
JDMRice
Dec 29, 2006 02:08 AM
yz125rider21
Dec 14, 2005 08:35 PM
boosted3g
Aug 30, 2002 12:06 PM
