eg sus on ef?
is this possible? we might be doing some coilover testing and i want to know if i can put eg coilovers on an ef. what would need to be changed to make it work??
-spenc
-spenc
i dont know if this would answer your question.. but I think it is possible
I am running DA GCs with EG KYB AGXs..... (aphabet soup)
yes, you do need to run front eg shock forks if you use the eg shocks
Modified by CRX25 at 8:11 PM 5/8/2003
the rear shocks from a eg will bolt onto a ef
the front struts are a little different
im runnin my bro's old weapon-r's off his eg with his rear shocks
i dont know if that helps but...meh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOLOef »</TD></TR><TR><TD CLASS="quote">is this possible? we might be doing some coilover testing and i want to know if i can put eg coilovers on an ef. what would need to be changed to make it work??
-spenc</TD></TR></TABLE>
All stock EG stuff won't fit. I tried a set of Neuspeed springs and stock 5g sturts and that didn't work. The fronts (with EG fork) were WAY too tall and would have given a good 4 or 5 inch RAISE - IF- I could have even pried the suspension open enough to force them in there. The shock was just too tall.
It's probably a totally different matter with aftermarket adjustable ride height coilovers with a shortened shock. I would say go with ED/EF stuff and not even bother with the EG parts.
-EDIT- Rears fit just fine.
yea, even with coilovers, the fronts may be an issue getting them low enough. we'll probably just get them in and see. if they dont work, thell go up for sale or back to the manufacter.
thanks for all the replies. big help.
-spenc
-spenc
724chris
Dec 16, 2009 10:47 PM
