type r head on my gsr block?
Old May 8, 2003 | 09:41 AM
white_98_gsr's Avatar
Default type r head on my gsr block?
Hey guys, this is my first post and i thought someone would know the answer to my question.
I can get a complete type r head for about $400.00. This includes the cams and valvetrain. I dont think it includes the intake manifold or distributer. And i can port and polish the head for cheap also.
So i was wondering what it would involve to put in on my 98 gsr? Would i be better off taking the cams and valvetrain out of the type r head and just putting in in my gsr. I know that the intake manifold flows much better and that the head is already ported somewhat on type r's, so i was just thinking of simply swaping the heads. And using only a 2 layer head gasket to put my compression back at 10.0:1
Do i need to mess with my ECU in order to run this head? (OBD II/OBD I). and what else do i completely need to do this swap?
thanks for your help
Old May 8, 2003 | 10:10 AM
NSX Bob's Avatar
New User
Default Re: type r head on my gsr block? (white_98_gsr)
You'll need an ITR intake manifold. How can you get the head so cheap? I would just drop in the internals and sell the bare head. At that price it is either hot, damaged, fake, or being offered to you by a very good friend.
Old May 8, 2003 | 11:25 AM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: type r head on my gsr block? (Type R Bob)
yea, for 400, you got hooked up, thats very cheap so its a a good head (not messed up), i say jus buy it ne wayz, a deal like that dun always come along
Old May 8, 2003 | 01:57 PM
gumbybum's Avatar
Default Re: type r head on my gsr block? (NA gs-R 05 C)
i think that you should buy it and sell it to me for that much
Old May 8, 2003 | 02:09 PM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white_98_gsr &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, this is my first post and i thought someone would know the answer to my question.
The Type R head will bolt right up to the GSR block. You said you want to use a two-layer gasket to bring your compression back up? Have you changed the compression in the GSR previously? A US GSR runs 10.0.1 already. Using a two layer and the fact that your using the type R will raise the compression some as is. Using a 2 layer will raise the compression .2-.3 points more. As for OBD II, and OBD I. I believe all the plugs will work the same except the plug for Vtec solenoid. I believe it's different, but you can just wire it directly so you should be fine. Overall it shouldn't be hard at all. Good luck.
P.S. You will need a type R or B16a intake manifold and throttle body. The GSR manifold will not bolt up to the Type R head, and the GSR IAC valve will not bolt up either… so I guess you will need IAC valve too…
Man, $400 was a good deal, but depending on what you get with it. Now you have to buy all this other ****!
Hope this helps…
Old May 8, 2003 | 05:18 PM
Default Re: type r head on my gsr block? (All-motor_JDMB18C)
yea, from what i heard, if you put the r head on the gsr block, it will lower the compression(still using stock gsr pistons) by about .2
So thats why i was planning on using the 2 layer head gasket to raise the compression back to what i previously would have had
Thanks for all the help so far.
any other thoughts would be appreciated
Old May 8, 2003 | 06:55 PM
b19coupe's Avatar
The Type-R head will lower compression, the combustion chambers are bigger. Are you absolutely sure that you are getting a Type-R head and not a B16 head? That is a little too cheap. While you have the head off, why don't you drop some ITR or CTR pistons in your engine? Just a thought.
jdm0ua
Jan 13, 2007 09:50 AM
dy5c00
May 6, 2005 03:25 PM
pikapp440
Aug 22, 2003 12:52 PM
GSRoadRage
May 28, 2002 05:22 PM
itr1236
Jul 14, 2001 09:32 AM
