pics of my ZC motor!
Old May 8, 2003 | 07:39 AM
joey1320's Avatar
Default pics of my ZC motor!
I'm trying with one to see if it works
Old May 8, 2003 | 07:41 AM
joey1320's Avatar
Default Re: pics of my ZC motor! (joey1320)
ok more pics...
pics of the parts coming soon.
Old May 8, 2003 | 07:57 AM
turboZChatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joey1320 &raquo;</TD></TR><TR><TD CLASS="quote">ok more pics...
pics of the parts coming soon.</TD></TR></TABLE>
Good **** what are your plans for it
Old May 8, 2003 | 08:07 AM
joey1320's Avatar
Default Re: pics of my ZC motor! (turboZChatch)
these are some of the parts that I'm putting on...
SRP pistons
Eagle rods
Centerforce clutch
JE rings
ARP bolts
plus everything else new... bearings/water pump/timing belt...
And for anyone putting a ZC together, the rods might hit the cilynders so some small modifications are needed... I just found out yesterday!
Old May 8, 2003 | 10:18 AM
Ronin Panda's Avatar
good luck
Old May 8, 2003 | 11:19 AM
DJ_SaNdOz's Avatar
Default Re: (Touge Panda)
what vdub bolts did you get?
Old May 8, 2003 | 12:45 PM
drjondurst's Avatar
Default Re: (dj_sandoz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj_sandoz &raquo;</TD></TR><TR><TD CLASS="quote">what vdub bolts did you get? </TD></TR></TABLE>
ARP now makes em for the ZC.
Old May 8, 2003 | 12:53 PM
sporkcrx's Avatar
Default Re: (drjondurst)
Did you hone those cylinder walls?
Old May 8, 2003 | 01:07 PM
joey1320's Avatar
Default Re: (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">Did you hone those cylinder walls?</TD></TR></TABLE>
I didn't know I had to so I'll be doing that tomorrow, thanks...
I should had asked before.
I'm getting the turbo tomorrow also for 150$.
T5/injector/smic/bov
Old May 8, 2003 | 01:46 PM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joey1320 &raquo;</TD></TR><TR><TD CLASS="quote"> And for anyone putting a ZC together, the rods might hit the cilynders so some small modifications are needed... I just found out yesterday!</TD></TR></TABLE>
you will have to notch the block to get those rods to not hit. there are some pics on http://www.theoldone.com. check them out.
also, i highly recommend getting a service manual if you are doing a rebuild. not knowing you need to do a honing shows me you need to do some research before doing this rebuild. i'm not trying to be an ***, just trying to help out.
Old May 8, 2003 | 02:45 PM
joey1320's Avatar
Default Re: pics of my ZC motor! (keithv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv &raquo;</TD></TR><TR><TD CLASS="quote">
also, i highly recommend getting a service manual if you are doing a rebuild. not knowing you need to do a honing shows me you need to do some research before doing this rebuild. i'm not trying to be an ***, just trying to help out.</TD></TR></TABLE>
I actually got the manual, and I asked plenty of times about the build up and no-one ever mentioned this before. Thanks for the help tough.
Old May 8, 2003 | 07:51 PM
boosted_zc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjondurst &raquo;</TD></TR><TR><TD CLASS="quote">
ARP now makes em for the ZC.</TD></TR></TABLE>
What's the part # for them, i need some. Thanks
--FELIX--
Sep 12, 2007 09:46 AM
B16CRXT
Feb 4, 2007 07:46 PM
inyoteef
Aug 22, 2006 07:37 AM
cyris3d
Sep 15, 2005 02:58 PM
Gee3
Nov 5, 2003 06:07 AM
