anyone know about this vtec add on lcd controler
Old May 8, 2003 | 04:04 AM
scottscotland's Avatar
Default anyone know about this vtec add on lcd controler
R-SPEC VTEC CONTROLLER is designed to provide full control over the HONDA VTEC engines. You can set the normal high cam switching point to below or above normal depending on the driving style.
Also this unit has a memory function to memorize two different high cam settings. MORE REASONS WHY YOU SHOULD OWN ONE...
1. TOTAL CONTROL OVER VTEC ENGINE: Set the normal cam switching point to below or above normal depending on your driving style. FEEL THE POWER OF VTEC!!!
2. DIRECT TWIN MEMORIES: Allow you change the setting to suite your driving style by pushing the SWITCH. With this function, you are able to have three settings of high cam switching point (normal, and two original settings). You can change the setting to suite your driving style by pushing the switch.
3. SPEED SENSTIVE HIGH-LIFT CAM CANCELLATION: Automatically avoid changing the setting of high-lift cam during slow driving (under 30km/h). FEEL THE VTEC TO THE EXTREME!!
4. DIGITAL TACHOMETER with SHIFT-UP POINT ALARM: Alarm will go off when the vehicle’s speed reaches the preset point.
5. DIGITAL SPEEDOMETER: CPU counts the speed pulse and transmits to the digital speedometer in split seconds. The error (actual vehicle speed and the figure appear on the speedometer) will automatically adjusted by the CPU.
6. SPEED LIMITER CANCELLER: During sport driving, you can cancel the speed limiter with this function (DO NOT USE THIS FUNCTION ON THE PUBLIC ROADS). This function is available to 98% of all Honda cars
7. CPU EQUIPEED: With advanced technology and design, this unit has provided the high performance and easy reliability in the compact body.
8. EASY INSTALLATION: It is easy installation with the original R-SPEC Vtec controller universal harness (INCLUDED FOR FREE).
-------------------------------------------------------------------------------- I will provide you with ONE UNIVERSAL HARNESS FROM R-SPEC for free and ONE English manual which will show you how to:
- Install the controller
- Operate the VTEC controller
R-Spec VTEC Controller will suit the following HONDA or ACURA model:
- CIVIC-----------------EF9-------------SEPT 87 ~ AUG 91
- CRX-------------------EF8-------------SEPT 89 ~ FEB 92
- INTEGRA------------DA6/ DA8-----APR 89 ~ SEPT 91
- CIVIC-----------------EG4/ EG6------SEPT 91 ~ AUG 95
- CIVIC FERIO--------EG8/ EG9-----SEPT 91 ~ AUG 95
- DEL SOL-------------EG1/ EG2------MAR 92 ~ JULY 97
- INTEGRA------------DA6/ DA8------OCT 91 ~ MAY 93
- CIVIC COUPE-------EJ1--------------FEB 93 ~ JAN 96
- PRELUDE------------BB1/ BB4------SEPT 91 ~ NOV 96
- INTEGRA (MT)-----DC2/ DB8------JUNE 93 ~ onwards
- ACCORD-------------CD5/ CD6------SEPT 93 ~ onwards
- ACCORD WAGON-CE1/ CF2-------SEPT 93 ~ onwards
- INTEGRA (AT)------DC2/ DB8------JUNE 93 ~ AUG 95
- NSX--------------------NA1-------------SEPT 90 ~ FEB 95
- PRELUDE------------BB6/ BB8-------DEC 96 ~ onwards
- CIVIC FERIO--------EK4/EX-------------SEPT 95 ~ AUG 98
- CIVIC TYPE-R------EK9--------------SEPT 95 ~ AUG 98
- INTEGRA-------------DC2/ DB8------OCT 95 ~ onwards
- INTEGRA TYPE R--DC2/ DB8------OCT 95 ~ onwards
THIS CONTROLLER WILL WORK FOR EITHER SOHC OR DOHC VTEC
HAS ANYONE TRYED IT AND HOW MUCH DO THAY COST I ALSO HAVE A PHOT BUT DONT KNOW HOW TO ATTACH http://cgi.ebay.com/ebaymotors...96890 found a photo
Modified by scottscotland at 1:18 PM 5/8/2003
bp944
Feb 1, 2013 10:52 AM
D-Rob
Engine Management and Tuning
Apr 14, 2008 11:39 PM
Jap_Spec_Imports
Apr 13, 2008 09:47 PM
d16dcoe45
Jul 15, 2005 05:23 AM
