b16 tranny
Old May 8, 2003 | 12:07 AM
roughrydin89's Avatar
Default b16 tranny
i just put a b16 in my 89 civic and are all dohc vtec tranny's gears closer together, i know going 55 mph in 5th gear, my tach is already at 3500 rpm's, does this seem normal, or could my tranny be built up a little....also, it feels a lot more torquier than my friends b16 that he just put in....could it be because i put in a stage 2 racing clutch...just curious
Old May 8, 2003 | 04:55 AM
REDBARON's Avatar
Default Re: b16 tranny (roughrydin89)
It depends on what tranny you have. The 1st generation B16's came with a few different ones. The S1 is the closest geared tranny, and is perfectly normal. I remember going almost 5K rpm when doing 80mph. As far as yours being torquier. I'd say it has to be with the close gears. You get higher in the powerband much faster.
Old May 8, 2003 | 05:26 AM
Rob!'s Avatar
Default Re: b16 tranny (REDBARON)
look on the front of your tranny there will be a gold stamp...its probably an S1...
Old May 8, 2003 | 08:52 AM
Rywire's Avatar
Default Re: b16 tranny (b16hf)
Your buddie prolly has a USDM LS tranny, while you likely have a J1, or S1 JDM tranny. The jdm trannies will accelerate quicker. Ryan
Old May 8, 2003 | 09:04 AM
fourthgenhatchB17's Avatar
Default Re: b16 tranny (droppedcrxsi)
Are there any other markings/stampings on the exterior part of the tranny so u know which one u have? I have a DOHC B series cable tranny but the sticker is no longer there and i want to know which one it is before dropping it in. I know on the SOHC trannys they have a stamping by the fill plug to let u know which one u got...
Old May 8, 2003 | 09:08 AM
Rywire's Avatar
Default Re: b16 tranny (fourthgenhatchB17)
Do you know if the tranny is USDM or JDM? Does it have LSD? How many splines on the imput shaft? These could be some clues. Ryan
Old May 8, 2003 | 09:11 AM
EL Vap133's Avatar
I think the easiest way for us to tell is if you take pics and show them to us...
Old May 8, 2003 | 09:21 AM
ViperRedCRX's Avatar
Default Re: b16 tranny (Vap133)
what is the gearing like for a y1?
Old May 8, 2003 | 11:32 AM
Default Re: b16 tranny (ViperRedCRX)
it's jdm and it says j1, thanks....and also, i have this little thing on the back of my tranny with 2 hoses coming off of it...my friends didn't have that, and my other friend got lsd with his tranny and it didn't have it....any ideas what this could be???
Old May 8, 2003 | 11:36 AM
DOHCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roughrydin89 &raquo;</TD></TR><TR><TD CLASS="quote">it's jdm and it says j1, thanks....and also, i have this little thing on the back of my tranny with 2 hoses coming off of it...my friends didn't have that, and my other friend got lsd with his tranny and it didn't have it....any ideas what this could be???</TD></TR></TABLE>
I have the same thing on mine..2 hoses coming up..i was wondering the same thing..i think it might lead to a tranny cooloer or somthing when it was in the car it came out of..i think i might just splice them together..what did you do with the hoses coming out of your tranny?
Old May 8, 2003 | 01:54 PM
Rywire's Avatar
Default Re: b16 tranny (DOHCRX)
I went to the hardware store, and got 2 little rubber caps (2 diff sizes) Ryan
Old May 8, 2003 | 02:36 PM
I think its a power steering bypass valve...what i did was swap over my SOHC speedo gear unit into the B series tranny. Looks a bit cleaner and its easy to do.
Old May 8, 2003 | 04:14 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
my S1 tranny sits at 5,5K RPM's at 70mph. Am I to assume my VDO tach isn't reading correctly?
Old May 8, 2003 | 08:19 PM
Default Re: (SeaBass)
WOW sea bass that seems like extremely high RPM's for only 70mph. I'd say something is off whether its ur tach (i doubt) or ur speedo. I know the S1 has the nice short ratios but dang, not that short.
Old May 8, 2003 | 08:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Do you know if the tranny is USDM or JDM? Does it have LSD? How many splines on the imput shaft? These could be some clues. Ryan</TD></TR></TABLE>
I dont know if it USDM or JDM, splines should all be the same with B series trannys(it was mated to my B17 when i got but i feel it was changed and is no longer the nice YS1). Dont ask me how i know...i just do. NO LSD. Any other ways to see which one it is without opening it up??
Old May 8, 2003 | 11:14 PM
i just put two bolts through each hose and called it good....the engine is such a tight fit in my car that you really have to look hard to see the hoses anyways
Old May 9, 2003 | 03:10 AM
TrevorHiroshima
Guest
Posts: n/a
that seems about right i have a b16a1 in my EF and it does that about the same cause i remember if i go over like 70 mph i'm hitting vtec... or i think i'm goign like 5k doing 70.. something like that
Old May 9, 2003 | 03:35 AM
bryant's Avatar
Default Re: (TrevorHiroshima)
http://www.ff-squad.com/Bgears.htm
there you go, it will tell you about how fast you are gonig and the gear and such. then you can identify your tranny. Sounds most likely like a S1/J1.
Old May 14, 2003 | 11:52 PM
Default Re: (Bryant)
thanks, yeah, it's a j1, i thought it was different than my friends, my friends hits at about 85 and vtec for me hits at about 100
crxsi8
May 13, 2006 07:08 PM
lmananT
Apr 21, 2006 11:21 AM
jaydm7182
Jan 25, 2005 08:07 AM
jaydm ferio
Jan 9, 2005 02:34 PM
