How is the MC reservoir attached to the MC?
Old May 7, 2003 | 09:44 PM
Floyd's Avatar
Default How is the MC reservoir attached to the MC?
Has anyone seen the reservoir separated from the MC? How to they fit together?
Old May 8, 2003 | 05:17 AM
Tweakmeister's Avatar
Default Re: How is the MC reservoir attached to the MC? (Floyd)
makes sense you'd be able to seperate it somehow...but I think it's sold as one piece anyway.
Old May 8, 2003 | 05:19 AM
.RJ's Avatar
.RJ
reman units generally have it attached anyways.
Old May 8, 2003 | 05:34 AM
Willard's Avatar
you can pull them apart.
loosen the clamp and slide it off and install it on the new master cylinder.
Old May 8, 2003 | 06:01 AM
Floyd's Avatar
Default Re: How is the MC reservoir attached to the MC? (Willard)
So the reservoir is clamped onto the MC, and once the clamp is removed it will slide off? What does the opening in the MC look like?
I'm not trying to replace my MC or anything, I'm wondering what it would take to put a reservoir tank from another vehicle on the MC.
(You guys probably think I'm an idiot... )
Old May 8, 2003 | 06:37 AM
JeffS's Avatar
If you're talking about an ITR MC, then there's no clamp. One screw holds the tab of the resevoir to the MC. Once you take the screw out, the resevoir just pulls off.
Yes, this one's broken...
Old May 8, 2003 | 06:48 AM
Floyd's Avatar
Default Re: How is the MC reservoir attached to the MC? (JeffS)
Thanks for the pic. That helps a lot. I was hoping that the inside of the holes on the top of the MC were threaded, but it doesn't seem that way. I'll have to rethink my plans.
Old May 8, 2003 | 07:23 AM
bdb's Avatar
bdb
I just went through this. My MC resevoir was leaking. You can't just buy the resevoir; I was told I had to buy the whole MC.
Old May 8, 2003 | 07:37 AM
norice's Avatar
Default Re: How is the MC reservoir attached to the MC? (bdb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdb &raquo;</TD></TR><TR><TD CLASS="quote">I just went through this. My MC resevoir was leaking. You can't just buy the resevoir; I was told I had to buy the whole MC.</TD></TR></TABLE>
Could you not just have bought a Tilton (or other aftermarket) unit? Not sure about fitment issues though.
Jon Petersen
Dec 23, 2018 02:47 AM
callmetree19
Nov 16, 2008 02:47 AM
DC5_lov3r
Apr 16, 2008 07:28 PM
higgunscrx
Jun 13, 2007 10:54 AM
nickgomez
Oct 4, 2003 09:36 PM
