Jumpy Idle
Old May 7, 2003 | 08:30 PM
MugenEF8CRX's Avatar
Default Jumpy Idle
After my car warms up I get a jumpy idle. It flucuates form 800-900-800 and so on. The motor is a 2nd gen B16A in a 91 CRX HF. I also eliminated the O2 sensor since I was only running one and it had a bad miss. The strange thing is I'm not throwing any codes for it. My main concern right now is the idle.
Old May 7, 2003 | 09:57 PM
MikeSarr_GSR's Avatar
Default Re: Jumpy Idle (MugenEF8CRX)
idles tend to get lopey when the valves are not set to spec. something I would look at. typically this happens when a few are too tight and others are to spec or a bit larger.
Old May 8, 2003 | 05:54 AM
OK, thanks. I was wondering if I could have air in my coolant system also? Would the fast idle vlave affect this? I'm going to set the timing today since I've had the dizzy off a few times. I'll set the valves too.
Old May 8, 2003 | 09:31 PM
Default Re: (MugenEF8CRX)
if you had air in the coolant the thing would run hot
Old May 8, 2003 | 09:56 PM
_Endless_'s Avatar
Default Re: (MikeSarr_GSR)
is there any way of getting rid of air in the coolant aside from flushing?
Old May 9, 2003 | 12:11 AM
Default Re: (_Endless_)
"burp" your baby y0
open the radiator cap when cold, let the bubbles come out by squeezing the upper radiator hose, then add coolant as you go as needed.
if you have a 95 GSR, it has a bleed valve... damn that 95gsr...
Old May 9, 2003 | 06:06 AM
Yea I went to go time my car and the light was burnt out so I need to find another timing light now. The idle, I'm still trying to find out what's wrong.
Ef4doorwagon
17
Apr 6, 2014 03:31 PM
mfzbike
Jan 17, 2009 05:03 PM
-HONDA-
Sep 4, 2007 12:00 PM
tpatt
Apr 28, 2007 05:21 AM
entityzero
Mar 26, 2007 07:44 PM
