butterflies on a b18c1
Old May 7, 2003 | 08:27 PM
Who Said's Avatar
Default butterflies on a b18c1
ive had my b18c1 for about a year now maybe, before i even put the motor in the car i installed skunk2 manifold. im running a stock 95 gsr ecu my question is since the ecu is looking to open the butterflies would this set a code but not bring up the
CEL and would this affect performance in anyway
Old May 8, 2003 | 12:22 PM
Who Said's Avatar
Default Re: butterflies on a b18c1 (super-dooper fast)
somebody gots to know this man
Old May 8, 2003 | 12:23 PM
Kamin's Avatar
no no performance problems
no codes.
Old May 8, 2003 | 12:26 PM
B_CRUZ!'s Avatar
It will not send off any codes.
Old May 8, 2003 | 12:40 PM
Kalokohan's Avatar
New User
You have PM.
BTW: Both Kamin & BCRUZ are correct.
Old May 8, 2003 | 01:02 PM
Nextelbuddy's Avatar
Default Re: butterflies on a b18c1 (Kalokohan)
i can tell u this get rid of that p72 with that ecu and your new skunk manifold u are losing hp and performance. i was using a p72 with my type r motor with teh single runner manifold and vtec kicked in at like 4400 u could hear it kick in but u didnt feel it pull till like 5800 rpms then it pulled hard. so getyour self a chipped p28 ecu its better i beleive in my book i have tried the skunk program and the mugen program at least 2 different versions of each and i have to say this jun program i have is the bomb it rawks all around.
Old May 8, 2003 | 01:59 PM
autoEXturbo's Avatar
if you are throwing a cel and no codes come up, the ecu is bad. You should probably go with a p28 and chip it otherwise your secondary runners won't work with the p72..
and don't listen to kalokohan he doesn't know anything
Old May 8, 2003 | 02:22 PM
Who Said's Avatar
Default Re: butterflies on a b18c1 (autoEXturbo)
yeah i have a stock p28 sitting in my room...just waiting to get cams and stuff before i chip it...my bro has a p72 chipped to type r specs..ill try that and see how it feels...thanks for the replys
Old May 8, 2003 | 02:28 PM
B_CRUZ!'s Avatar
FYI: a chipped p72 and p28 is the same(if they have the same chip). the ecu will run the settings off of the chip.
So don't believe someone if they say 'my chipped p28 is better than a chipped p72'.
Old May 8, 2003 | 03:15 PM
SOHC_DK.'s Avatar
Default Re: butterflies on a b18c1 (BCRUZ)
someone please explain the "butterfly" thing.. I do not know what it is???
M. Nielsen.. Denmark
Old May 8, 2003 | 03:17 PM
Slurp56's Avatar
Default Re: butterflies on a b18c1 (SOHC_DK.)
butterflies = 2nd set of intake runners:
Old May 8, 2003 | 03:51 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BCRUZ &raquo;</TD></TR><TR><TD CLASS="quote">FYI: a chipped p72 and p28 is the same(if they have the same chip). the ecu will run the settings off of the chip.
So don't believe someone if they say 'my chipped p28 is better than a chipped p72'.</TD></TR></TABLE>
Yeah, unless their chipped p72 still has the programming for the butterflies and they're still running the dual stage manifold. I had a P72 XSE chip for awhile like that.
Old May 8, 2003 | 10:17 PM
Who Said's Avatar
yeah but doesnt the p72 look for a knock sensor...anyway that doesnt matter cause i have mine wired.
i still need to chip mine though cause my brothers' car is gonna be on the road again soon
Old May 9, 2003 | 07:26 AM
Doeboy's Avatar
p28 skunk2 with a v-afc or you will run rich
Old May 9, 2003 | 10:14 AM
Who Said's Avatar
Default Re: (onefastcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefastcivic &raquo;</TD></TR><TR><TD CLASS="quote">p28 skunk2 with a v-afc or you will run rich</TD></TR></TABLE>
huh?
hatchet_honda
Apr 6, 2011 09:59 PM
94eh2
10
Sep 30, 2007 06:00 PM
vtec25
12
Apr 17, 2006 05:40 AM
964dgsr
Mar 2, 2004 10:03 AM
92 CiViC gsR
Mar 8, 2002 02:18 PM
