toda header install problem - immediate help needed!!!
Old May 7, 2003 | 08:15 PM
magic hat #9's Avatar
Default toda header install problem - immediate help needed!!!
ugh, it's 12am.
i've got the toda header, carsound cat, and oem exhaust all lined up and everything mates perfectly together. the problem is the support bracket on the toda header is too far from the corresponding bracket on the car!? do i have the wrong header? there is no way to bend the bracket as it will hit the axle. help!!!
Old May 7, 2003 | 08:20 PM
thk's Avatar
thk
Members Only
Default Re: toda header install problem - immediate help needed!!! (magic hat #9)
You can either just remove the USDM bracket and run without one or order a JDM bracket.
Old May 7, 2003 | 08:23 PM
BlueR's Avatar
Default Re: toda header install problem - immediate help needed!!! (thk)
you need the jdm bracket...dumbass
Old May 7, 2003 | 08:24 PM
where to get this jdm bracket?
i can't believe it's good for the header (or block) to carry the stress of supporting the cat/header during driving.
Old May 7, 2003 | 08:26 PM
BlueR's Avatar
i run my toda without it...
the spoons/todas are not that heavy...
now if i had the jdm 4-1...that would be a different story
aaron...lemme see if i can locate one for you tomolo
Old May 7, 2003 | 08:33 PM
B2FiNiTY's Avatar
I would recommend you to not buy a jdm bracket. They often break and often cause headaches.
Now go bolt it up!
Default Re: toda header install problem - immediate help needed!!! (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">aaron...lemme see if i can locate one for you tomolo </TD></TR></TABLE>
yes, please do - thank you!!!
anybody else have a spoon/toda header that doesn't use the bracket?
B2FiNiTY's Avatar
Spoon does not have a bracket.
Old May 7, 2003 | 08:36 PM
Default Re: toda header install problem - immediate help needed!!! (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Spoon does not have a bracket.</TD></TR></TABLE>
i would still like the bracket. i guess i'm a bit paranoid after removing so many bolts to get the heavy oem manifold off the car.
ok, off to bolt this **** up and drive it. shouldn't you guys be in bed?
Old May 7, 2003 | 08:37 PM
BlueR's Avatar
thank you dennis...
i've owned both too
but the weight issue still makes sense to me
Old May 7, 2003 | 08:39 PM
B2FiNiTY's Avatar
Bolt it up and let her rip! Spray some windex on the header and wipe it down...it cleans it up real nice just in case.
Old May 7, 2003 | 08:48 PM
Christian's Avatar
No need for the bracket. I don't use one. And my new Hytech doesn't have one either.
Old May 7, 2003 | 08:53 PM
bus stop's Avatar
The header you got is design for PY ITR not black itr......give it to me
anyway, good luck with the install
Old May 7, 2003 | 09:00 PM
Dr Pooface's Avatar
Default Re: toda header install problem - immediate help needed!!! (WhosITR)
No bracket needed.
Old May 7, 2003 | 09:23 PM
Mike M's Avatar
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I would recommend you to not buy a jdm bracket. They often break and often cause headaches.
hehe Mine was kinda the opposite. The Bracket on the Toda Header broke off the header but the JDM Header Bracket itself didn't break
Old May 7, 2003 | 10:02 PM
Default Re: toda header install problem - immediate help needed!!! (Mike M)
done! i started her up (no exhaust leaks that i could hear) and ripped down a backroad. i definitely felt a bit more of a power surge going into vtec and the car sounds slightly (hard to tell with rain and no interior ). off to bed with me.
thanks for the help
Old May 7, 2003 | 10:05 PM
yeer's Avatar
damn i wish someone will sell me a toda header for cheap.
Old May 7, 2003 | 10:08 PM
Dan GSR's Avatar
&lt;------ Picturing Aaron twisting his body under the car to take that pic....lol
Old May 7, 2003 | 10:09 PM
nEoMuGen's Avatar
Default Re: toda header install problem - immediate help needed!!! (yeer)
Toda header will not run properly without the brackets under extreme conditions such as AutoX and HPDEs. Spoon ones are more lightweight because its more JDM.
I am known to be nice. So I'll trade my Spoon for your Toda + $100.
Old May 7, 2003 | 10:15 PM
Kelvin96GSR's Avatar
25 Year Member
Default Re: toda header install problem - immediate help needed!!! (nEoMuGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nEoMuGen &raquo;</TD></TR><TR><TD CLASS="quote">Toda header will not run properly without the brackets under extreme conditions such as AutoX and HPDEs. Spoon ones are more lightweight because its more JDM.
I am known to be nice. So I'll trade my Spoon for your Toda + $100.</TD></TR></TABLE>
LOL
I ran without the bracket in question.
Old May 7, 2003 | 10:17 PM
GettaluvR's Avatar
New User
so all the JDM header would have the same problem ? or just spoon and toda.
wonder if mugen would cost the same problem
Old May 8, 2003 | 12:44 AM
chinkiechunkie's Avatar
i dont use the bracket. never had a problem.......
Old May 8, 2003 | 12:54 AM
SurferX's Avatar
There is the 96spec/USDM bracket and then the 98spec bracket. Whatever year car the header says it's made for will be what bracket you'd be needing to use.
My bracket snapped in half with my DC JDM, so I took it off. My current header also has no bracket at all. Aftermarket 16-gauge stainless steel headers aren't as heavy as the stock manifold so I don't think it's a big deal. Plus the weight is also supported by the exhaust down the collector.
Old May 8, 2003 | 05:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nEoMuGen &raquo;</TD></TR><TR><TD CLASS="quote">I am known to be nice. So I'll trade my Spoon for your Toda + $100.</TD></TR></TABLE>
haha, it might've worked last night, ray ray, but now i've rested and i'm sharp as a tack so no fooling around. i'll trade your spoon for my toda + $200! fear my regotiation skillz.
Old May 8, 2003 | 06:00 AM
Dels98R's Avatar
mine did not line up either i have the mugen ones but i just un bolted the bracket, works fine bro
