Engine noises
Old May 7, 2003 | 08:12 PM
bLuEciVicGuY's Avatar
Default Clutch noises
When I turn my car on and let it idle, it makes a clicking like noise.But when I step down on the clutch,the noise is gone.What is that noise I'm hearing.
Modified by bLuEciVicGuY at 10:25 PM 5/8/2003
Old May 7, 2003 | 08:13 PM
.RJ's Avatar
.RJ
Default Re: Engine noises (bLuEciVicGuY)
throwout bearing
Old May 7, 2003 | 08:21 PM
scn095's Avatar
Default Re: Engine noises (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">throwout bearing</TD></TR></TABLE>
Yep... probably.
Old May 7, 2003 | 08:25 PM
ScottEK's Avatar
Mainshaft bearing, not throwout bearing.
Anyone care to explain to me why you would even think it was the throwout bearing? Clutch is up, release spring pulls back the bearing, the throwout bearing isn't even moving!?!
Old May 7, 2003 | 09:30 PM
.RJ's Avatar
.RJ
Default Re: Engine noises (beta13)
It doesnt need to be moving to rattle around
Old May 8, 2003 | 01:39 AM
So is it mainshaft or throwout??????????
Old May 8, 2003 | 04:31 AM
.RJ's Avatar
.RJ
throwout
how many miles on the clutch/throwout bearing?
Old May 8, 2003 | 09:41 AM
ScottEK's Avatar
I still think it's the mainshaft, are there any other symptoms? Does 1st and 2nd gear sound like there whining? You would have gotten more responses if you titled it clutch noise or transmission noise.
Old May 8, 2003 | 09:24 PM
how many miles on the clutch/throwout bearing?</TD></TR></TABLE>
I say about 25k on it.
Old May 10, 2003 | 03:48 PM
anyone else.
Old May 10, 2003 | 04:00 PM
Chiovnidca's Avatar
Default Re: Clutch noises (bLuEciVicGuY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bLuEciVicGuY &raquo;</TD></TR><TR><TD CLASS="quote">When I turn my car on and let it idle, it makes a clicking like noise.But when I step down on the clutch,the noise is gone.What is that noise I'm hearing.
Do you have to push the clutch more than halfway down for the noise to go away? Or do you just have to touch the pedal?
Old May 11, 2003 | 02:36 PM
Default Re: Clutch noises (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Do you have to push the clutch more than halfway down for the noise to go away? Or do you just have to touch the pedal?</TD></TR></TABLE>
I have to push the clutch all the way down to the ground.
Old May 11, 2003 | 02:44 PM
Chiovnidca's Avatar
Mainshaft bearing maybe?
Old May 11, 2003 | 03:52 PM
scn095's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone care to explain to me why you would even think it was the throwout bearing? Clutch is up, release spring pulls back the bearing, the throwout bearing isn't even moving!?!</TD></TR></TABLE>
Damn it! You're right; I read it backwards! When my transmission did this it was the mainshaft bearing.
Old May 11, 2003 | 07:38 PM
Default Re: Engine noises (scn095)
Thanks for the reply.I will check it out.
Old May 11, 2003 | 09:20 PM
wm5holla's Avatar
when ur gears are looose is that bad...do you understand?
Old May 11, 2003 | 10:27 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Engine noises (wm5holla)
input shaft , which is on the mainshaft, bearings are common also. does it whine goin down the road?
Old May 12, 2003 | 05:15 PM
Default Re: Engine noises (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">input shaft , which is on the mainshaft, bearings are common also. does it whine goin down the road? </TD></TR></TABLE>
NO it doesn't whine.
Old May 12, 2003 | 05:29 PM
B-Tuning.com's Avatar
Input shaft bearing.
Fix it now or you'll be replacing a whole lot more than just that one. If you can take the tranny out and follow a Helms, you can do the job yourself. Otherwise, pull the tranny and take it into a shop - you'll save the R&R Labor.
Old May 12, 2003 | 07:19 PM
Mr. Badwrench
NO it doesn't whine.</TD></TR></TABLE>
more than likely it is the throw out bearing then.
Old May 12, 2003 | 11:11 PM
crxtreme27's Avatar
I am having the same problem... i have to step on the clutch for the noise to go away and mine does wind when im in first or second gears.. how long do i have till i cant drive it no more???
Old May 13, 2003 | 12:15 AM
Default Re: Engine noises (crxtreme27)
A Thank you goes out to everyone that reply.I'm gonna go get it fix now.
Old May 13, 2003 | 12:39 AM
MikeSarr_GSR's Avatar
Sounds like the splines on the clutch disk hub are rounding out with the clutch disk rattling on the input shaft. more than likely it is an aftermarket (cough** ACT) clutch. It happened to me. If the splines are supposed to be 2mm across each for ex. and the forces exerted on the disk have caused the metal to fatigue, the tracks on the hub grow to say 3-4mm each. you get a rattle that sounds like a click then a knicka then a knock... push in the clutch it goes away... the stock disks are forged on the inner hub... most aftermarkets are not... my ACT disk friction surface would have lasted longer than the inner hub... sad huh. I had about 1/2cm of play in the disk if moved from side to side on the input shaft... put on an LS disk with 22K on it... no play at all... and its been in my car for another 21K hard driving with an OLD JDM B16a PP that looked like it was on the bottom of a lake.../GSR throwout bearing with 20K. Still holds fine with 160/122 at the wheels...
StockDC2
Jul 8, 2017 11:48 AM
akacoke
Jun 27, 2011 10:48 AM
93 EG
12
Mar 3, 2007 08:14 AM
00siandrew
Apr 13, 2006 05:09 PM
98GeeYes-Are
Feb 22, 2004 06:09 PM
