***B20 into a CRX dx...what type of intake manifold to use?***
The search was unclear...I want to put a b20 into a '89 crx dx and want to know what kind of intake manifold AND INTAKE will I need to put on it to make it clear the hood(or will the stock one off the b20 work fine??)....Also whats the best tranny to pair up with a b20 for an all motor daily driver?? (I'll be putin a vtec head on it later when I save up money!) THANX!
any ls mandfolds will work. the b20 will work if its not the big tall one if the car is going to stay all motor i would get a b 16 with lsd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerus »</TD></TR><TR><TD CLASS="quote">I think you have to use a 90 to 91 integra obd0
mandfold,injectors and dist. but not sure.</TD></TR></TABLE>
Stay away from the 1990-1993 LS intake manifold!! The intake runners on this manifold are MUCH smaller than the ports on the B20 and will NOT match up. This will pose a major restriction. Instead, go with either a 1994-1995 LS intake manifold or a Skunk2 intake manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">
Stay away from the 1990-1993 LS intake manifold!! The intake runners on this manifold are MUCH smaller than the ports on the B20 and will NOT match up. This will pose a major restriction. Instead, go with either a 1994-1995 LS intake manifold or a Skunk2 intake manifold.</TD></TR></TABLE>
What!!??
I need some one to confirm this!! (about the 94-94 ls part)
What!!??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russian_racer »</TD></TR><TR><TD CLASS="quote">
What!!??
I need some one to confirm this!! (about the 94-94 ls part)</TD></TR></TABLE>
That's what I have been told as well. You can run a intake manifold from a OBDI engine and still use you OBD0 injectors. If you don't want to convert to OBDI.
What!!??
I need some one to confirm this!! (about the 94-94 ls part)</TD></TR></TABLE>That's what I have been told as well. You can run a intake manifold from a OBDI engine and still use you OBD0 injectors. If you don't want to convert to OBDI.
