Master Cylinder Question
Old May 7, 2003 | 05:33 PM
kungfuSiR's Avatar
Default Master Cylinder Question
I just switched over to a set of 11" Front Brakes from fastbrakes into my 1999 Honda Civic SiR, and i think i need a new master cylinder. The shop i take my car to has a wrecked prelude sitting there with a fresh master cylinder, but my question is will it fit into my car, and even more importantly will it bolt up to my brake booster?
Thanks for your input
Old May 7, 2003 | 05:43 PM
.RJ's Avatar
.RJ
Default Re: Master Cylinder Question (kungfuSiR)
You dont want to mix-and-match brake system components, even if it does fit.
Old May 7, 2003 | 06:03 PM
dfoxengr's Avatar
Default Re: Master Cylinder Question (.RJ)
you have an 11/16ths now right? whats the point?
Old May 7, 2003 | 06:58 PM
kungfuSiR's Avatar
Default Re: Master Cylinder Question (hybridvteceg)
I thought the 2001 Prelude MC was a 1"
Old May 8, 2003 | 03:01 AM
dfoxengr's Avatar
it probly wont work anyways, but 1" wont give u that much difference over 15/16ths
Old May 8, 2003 | 06:51 AM
JimBlake's Avatar
1" gives you almost 14% less fluid pressure vs. 15/16".
Old May 8, 2003 | 07:57 PM
kungfuSiR's Avatar
Default Re: Master Cylinder Question (JimBlake)
Less or more? I don't get how a 1" MC would give you less fluid pressure then 15/16"
Old May 8, 2003 | 08:14 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kungfuSiR &raquo;</TD></TR><TR><TD CLASS="quote">I just switched over to a set of 11" Front Brakes from fastbrakes into my 1999 Honda Civic SiR, and i think i need a new master cylinder.
Thanks for your input</TD></TR></TABLE>
fast brakes use stock calipers? if so you arent moving any more fluid volume. thus you shouldne need a bogger bore master cylinder.
Old May 9, 2003 | 04:04 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kungfuSiR &raquo;</TD></TR><TR><TD CLASS="quote">Less or more? I don't get how a 1" MC would give you less fluid pressure then 15/16"</TD></TR></TABLE>
Using the same vacuum booster? If so, you have the same force on the piston rod, larger piston area. If you use a different booster along with the bigger MC, then the size of the diaphragm in the booster has to be figured in there.
You want more braking force? Use a smaller MC and/or larger caliper pistons. The mechanical advantage of the hydraulic system is equal to the caliper piston area divided by the MC piston area.
Old May 9, 2003 | 02:07 PM
kungfuSiR's Avatar
Default Re: Master Cylinder Question (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
fast brakes use stock calipers? if so you arent moving any more fluid volume. thus you shouldne need a bogger bore master cylinder.</TD></TR></TABLE>
THey use the ITR/Accord/Prelude Calipers
JonasG93
18
Apr 21, 2015 07:22 AM
Del Sol on Steroids
Mar 6, 2008 09:25 AM
justforkicks
Sep 10, 2006 11:47 AM
Supra
Jul 10, 2005 05:46 PM
Tlex
Apr 15, 2002 10:06 PM
