I keep getting a code for the map sensor.
Old May 7, 2003 | 05:27 PM
EFLaosGirl's Avatar
Default I keep getting a code for the map sensor.
I went and bought a new missing link and switched my map sensor to the original one that came out of the car. I still get the code. If I drive the car normally for like a couple minutes the car will cut off on me and throw code 3. If I cut off the car the CEL goes off untill I drive it again. If I kick it a lil bit and tach it to like 5000 rpms the fuse blows. Any one know what this could be?
Old May 7, 2003 | 05:38 PM
MONSTERZC's Avatar
Default Re: I keep getting a code for the map sensor. (EFLaosGirl)
what fuse is it blowing something is shorting out if the fuse is blowing double check your wiring harness for any cuts or anything like that
Old May 7, 2003 | 05:43 PM
EFLaosGirl's Avatar
Default Re: I keep getting a code for the map sensor. (MONSTERZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MONSTERZC &raquo;</TD></TR><TR><TD CLASS="quote">what fuse is it blowing something is shorting out if the fuse is blowing double check your wiring harness for any cuts or anything like that</TD></TR></TABLE>
I thought it was because of the wire that was pinched in my fuel pump. After we fixed that it was ok for a day or so. Then it happend again. But it wasn't as bad as was before. We checked the wiring.
Old May 7, 2003 | 05:44 PM
EFLaosGirl's Avatar
oh yeah number 14 fuse is the one that blows
relentlesstech
Apr 10, 2014 06:22 PM
MooG1337
Acura TSX
Oct 7, 2012 05:30 PM
EKB18BPR3
Jun 20, 2005 04:18 PM
cjames235
Dec 27, 2003 06:17 AM
