i cant tell which wire on dizzy is which
Old May 7, 2003 | 02:32 PM
AGPSuperstar's Avatar
Default i cant tell which wire on dizzy is which
can someone point to me where each wire on the plug is....some of them are faded and i can't tell which one im supposed to rewire for my MPFI conversion....help please thanks agp
Old May 7, 2003 | 02:50 PM
Default Re: i cant tell which wire on dizzy is which (AGPSuperstar)
bump
Old May 7, 2003 | 02:54 PM
TheHatchHog's Avatar
I rewired mine but if you seen the topic i just posted up, I do not know if I did it correctly... I am pretty damn sure that I did though, so I dont know what is up with mine??? What wires dont you know about??? all connect to your DX harness exept 2. For the crank angles....
Old May 7, 2003 | 02:59 PM
88rexdxa6ed's Avatar
Default Re: i cant tell which wire on dizzy is which (civicciviccivic)
the blue\yellow and blue\green got to your ecu. the rest are the same color. when thewre faded you just trace them back a few inches and they should be not as faded. make sure you don't mix the solid white wires, one is thicker than the other.
Old May 7, 2003 | 03:20 PM
Default Re: i cant tell which wire on dizzy is which (88rexdxa6ed)
This is where I think I screwed up. Do you run the blue/green, and blue/yellow wires seperate to the ECU. and do the other five wires plug into the DX harness? If so What locations do the Blue wires go to into the ecu? Please help.
f20bcl
Jul 23, 2010 07:55 AM
thatHEMIguy
Mar 4, 2010 08:57 AM
sedan squad
10
Mar 19, 2006 11:33 AM
88rexdxa6ed
14
May 6, 2003 01:56 PM
paybac4223
Mar 19, 2003 11:00 AM
