GSR Tranny Problems???
Old May 7, 2003 | 02:07 PM
JDMCivicEF9's Avatar
Default GSR Tranny Problems???
A friend of mine has run into a big problem. His 99 GSR tranny is messed up, it won't go into gear. It will only go into gear when the engine is off, but when the engine is on it just won't go in. We checked the tranny fluid and clutch fluid and its all ok. What could be the problem?
Old May 7, 2003 | 02:28 PM
MikeSarr_GSR's Avatar
Default Re: GSR Tranny Problems??? (JDMCivicEF9)
sorry to be the one to break it to you.
if you cannot feel the "tree" the change peice is broken.
if you can feel the "tree" and cant get any gears, your synchro hubs are so
badly worn that the sychros cant work properly.
you need someone to drop your tranny and pull the shafts and diagnose it.
thats a big job. if you lived here in FL I would give you to my guy. I had to
do my 3-4 synchro hub and rings recently, change out two selector forks and
a change peice also. My tranny was majhorly fooked. If I were you, I would
look into finding a used ITR tranny and upgrade, sell this thing for slag. In
its current state the gears, shafts and casing would be worth $200 alone.
Old May 7, 2003 | 02:44 PM
TREVER's Avatar
Default Re: GSR Tranny Problems??? (MikeSarr_GSR)
the tree?
Put it in gear engage the cluth and start it. If it doesn't move the clutch is gone.
Old May 7, 2003 | 02:50 PM
Default Re: GSR Tranny Problems??? (TREVER)
yea... thats me always thinking worst case scenario.. it could be just the clutch
Old May 8, 2003 | 05:26 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREVER &raquo;</TD></TR><TR><TD CLASS="quote">the tree?
Put it in gear engage the cluth and start it. If it doesn't move the clutch is gone.</TD></TR></TABLE>
What??
If the clutch is engaged, the interlock won't let you start it. You press in the pedal to DISengage the clutch. If you do that & the car tries to move, then your clutch is dragging (doesn't completely disengage) and that's why you can't shift with the engine running. It could be clutch master cylinder bypass or a warped clutch disk, or some other things...
What's the "tree"? I'm guessing what he means is... With the engine turned off, can you feel all the gates? Or does the shift lever just flop around like it's not connected to anything?
Old May 8, 2003 | 05:33 AM
.RJ's Avatar
.RJ
Its probably busted springs on the clutch disc. Time for a new clutch.
Old May 8, 2003 | 06:45 AM
Default Re: GSR Tranny Problems??? (.RJ)
the "tree" as I understand it is how the changepeice actuates the selector forks in
the tranny case. the selector forks drive the synchro hubs that engage the gear while moving. I take it you havent seen a broken down tranny in peices, its ok.
so the "tree" is the slots where you percive to move the shifter into its notches. that comes from the changepeice. I broke the pin offa that, so my car didnt have a tree at all at one time. Stuck in 4th gear. Fun Huh!?
yea shift gates would be the more widely known term.
Old May 8, 2003 | 07:27 AM
REDBARON's Avatar
This happened to my brother's CRX. I'm not sure if it applies since it's a different car, but he replaced the clutch and it worked fine.
Old May 8, 2003 | 08:31 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">... I take it you havent seen a broken down tranny in peices, its ok.</TD></TR></TABLE>
Everybody's got different names for that stuff. We had an aircooled VW years ago, by brother managed to get the shift rod into the neutral position while the 1/2 fork was still engaged in 2nd. So as long as he kept the lever in neutral, he could drive home in 2nd. If he put it into any other gear it would lock up 'cause 2 gears were engaged at once. Fun, huh? Our dad wasn't real pleased...
Old May 8, 2003 | 08:38 PM
Default Re: GSR Tranny Problems??? (JimBlake)
yea its even worse when you are the "Dad" and the "kid" all at the same time and it comes outta your own ***.
tgreaves
Feb 2, 2004 07:09 AM
hdeuce
Sep 3, 2003 02:02 PM
sl0wED
Feb 14, 2003 06:10 AM
