Thoughts on piston install
Old May 7, 2003 | 01:30 PM
Beave0101's Avatar
Default Thoughts on piston install
My funds will dry up towards the end of this summer, so i'm trying to complete my engine by than. If not the (below mentioned route) i will save up over the course of the next few monthes and go with aftermarket rods/pistons.
For what seems like forever now, I have my skunk2 stage 2 cams, springs, retainers, PE belt, ITR manifold, and every single gasket and seal that can be replaced on the head...just sitting there.
In a few weeks I'm going to rip off the head and have a 3 angle valve job & a port & polish done.
But now my concerns are with compression. The motor is a B16A2, (10.2.1 ) and will have to run on 91 octane. So i thought something a higher, but not too high would do nicely for me.
If the head is off, should I consider throwing in some B16B pistons ? With a spoon gasket that would yield an 11.1 compression ratio, which would be just fine.
Without going overbore, just the stock size replacement, if i have some people that know how to do a re-install, do i HAVE to hone the block? And can this be done with the block still in the car? And what needs to be balanced ? In every search i've found, you have to hone the block, but I've talked to so many people that just drop the new pistons right in.
Old May 7, 2003 | 01:40 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Thoughts on piston install (Beave0101)
I`d go ahead and bump teh compression up. It`s cheap power.
Old May 7, 2003 | 01:45 PM
Spade's Avatar
Default Re: Thoughts on piston install (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">I`d go ahead and bump teh compression up. It`s cheap power. </TD></TR></TABLE>
I agree.
joe_bocc's Avatar
Its best to hone the cylinders because you will be installing new pistons, which means new rings. For the rings to seat properly, you should hone the block.
Old May 7, 2003 | 02:14 PM
Beave0101's Avatar
Default Re: Thoughts on piston install (joe_bocc)
alright, i just wanted to verify it's needed.
So can this be done with head taken off, and the block in the car ?
thanks guys
Old May 7, 2003 | 02:24 PM
lazy bum shaughn's Avatar
Since you are taking the block out to get honed, you might as well go with Civic Type R oversized pistons. They are .25 overbored.
Old May 7, 2003 | 03:00 PM
sgT's Avatar
sgT
Default Re: Thoughts on piston install (lazy bum shaughn)
with the spoon gasket it will be closer to 11.5:1 but thats evenbetter.
Old May 7, 2003 | 03:55 PM
dfoxengr's Avatar
Default Re: Thoughts on piston install (sgT)
dont spend money on a spoon gasket when uc an get a cometic for 80$...high comp
ben h
15
Apr 24, 2012 01:08 PM
xander1100
Nov 29, 2008 07:13 AM
NathanMorris
Jul 28, 2006 05:59 PM
gundamgsr
May 23, 2004 11:14 PM
JunCivic Hatch
Jan 10, 2002 05:15 PM
