Could anything other than a bad dizzy throw a crank angle sensor code?
I mean like really bad ignition timing or timing belt being off a tooth or anything like that?
I ask because I've swapped dizzy's and checked wires from ecu harness to dizzy harness and continue to get the code. b16a1 in a 91 crx si wth 90 ls dizzy.
Thanks for any info
Thanks for any info
I've got the same problem. This was after I re-did the wiring on my swap to clean it up. I tried two dizzys and I mapped out all the dizzy wires.\
Have you had any luck?
crxfreak1117
Nov 28, 2007 05:56 AM
nayrone
Nov 1, 2004 12:09 PM
Blaze45
Dec 13, 2003 06:28 PM
